View Poll Results: Awesome?
Voters
12. You may not vote on this poll
  • Indeed
    11 91.67%
  • Nope
    0 0%
  • Maybe, I'll tell you why below
    0 0%
  • What's going on...
    1 8.33%
Multiple Choice Poll.
Page 6 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 51 to 60 of 158
Like Tree1Likes
Thread: ** NEW ** Fusion Control Centre's Fusion Volume Knob!
  1. #51
    Mar 2006
    Colorado, but Canadian!
    I have the device doing composite USB, so config and volume control at once. I can change the lights and everything like that. I am working on the final bit of code to be able to programmaticly store the values to the internal flash memory, that way it "remembers" the light config between unplugs.
    1.9in x 2.9in -- 47mm x 73mm
  2. #52
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    thanks 2k1... first product in my opinion that I've been waiting on...
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  3. #53
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    So... any updates?
    Sent from my DROID BIONIC using Tapatalk 2
  4. #54
    Mar 2006
    Quote Originally Posted by nasa View Post
    So... any updates?
    It works
    Everything seems to be working, but I am still testing.
    I think I am at the point where I can open it up to beta-customers. Those that don't mind there may be some firmware updates or software updates. It should work.
  5. #55
    Mar 2012
    So how will one get in this beta program? Do you just consider the first people to buy it from the store to be beta testers or do we need to contact you directly?
    Sent from my HTC One X using Tapatalk 2
  6. #56
    Aug 2007
    Queens, NYC
    i wanna beta test too
    CarPc
    Project "Driver"
    Planning [99.9%]
  7. #57
    Aug 2006
    PA
    Me Too!
  8. #58
    Mar 2011
    Ohio
    Me Too!
    Me Three! I feel like I've been watching this thread for ages! Waiting excitedly.
  9. #59
    Sep 2005
    I'll volunteer too :-)
    Car news and wallpaper site: www.carfeed.net
  10. #60
    Mar 2006
    Ok,
    If you want to be a beta-tester then please email me your PayPal email address and a shipping address (so I can see what shipping will be) to [email protected] and I will send you a manual invoice. If you are within the US, it won't be more than $5 shipping (flat rate box) but it should be less because it is not that voluminous so I should be able to stick it in something else. Outside the US, it will probably be $15 because that is the international small flat rate box rate and that is generally the best method for small things outside of the states (and no broker fees).
    The current MSRP thought is $28 to $35 a piece. For you beta testers, $20. For anyone reading this thread in the future, no you can't have that price.
    As a beta tester I would hope that you would (a) use the device obviously and (b) give me some feedback on it.
    So currently the only known bug is when you switch directions. It takes 2 detents to change direction, but 1 to change the volume. This was an unexpected result of a change to the firmware to make the device more robust. Because these are mechanical signals there is bouncing. To take that bouncing away, the input is filtered. The filter I implemented basically makes sure you are spinning the same direction. It is really only noticeable if I tell you (now you'll notice!) but I am hoping some magic software goo might de-bug it.
    Everything else is functional. So turn the knob anti-clockwise and the volume goes down. Turn the knob clockwise and the volume goes up. Press the knob in once and it mutes. Press again and it unmutes. It is a high quality free spinning optically encoded rotary device so you can spin it forever and it will never reach an end point. That also means you can adjust the volume on the PC or any other place, and the knob will never become "out of sync" because there is no sync to begin with. The LED lighting of the shaft is controlled by 3 independent small LEDs located directly below the shaft: A red one, a green one, and a blue one. You can select a value between 0 (off completely) and 255 (on completely) for each LED. The result is any 24bit colour, or 16million unique colours. You should be able to take the HEX value from photoshop or anything, input those RGB values and make it that colour.
  1. Replies: 7
    Last Post: 01-26-2014, 10:24 AM
  2. ** NEW ** Fusion Control Centre's MEGA-Relay Board
    By 2k1Toaster in forum Fusion Brain
    Last Post: 12-20-2011, 06:39 PM
  3. ** NEW ** Fusion Control Centre's Mini-Relay Board
    Last Post: 12-20-2011, 06:37 PM
  4. Fusion Control Centre & Fusion Brain v6
    By waltersaegir in forum Fusion Brain
    Last Post: 09-21-2011, 07:56 PM
  5. fusion brain v4 car control
    By hachacker5024 in forum Fusion Brain
    Last Post: 07-15-2009, 12:13 PM
