Results 1 to 10 of 18
Thread: MS Paint to edit default skins?
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    I gave up trying to create my own gauges, don't know enough. Tried to change existing oil temperature static image to an oil pressure gauge background. Modified it in MS Paint and saved it back as PNG in same folder as original. When I try to switch it out in configurator it says "Invalid Image; Image is not a supported file type"
    Variable Bitrate Deric's Avatar
    Sep 2006
    I wouldn't use paint. If you don't have access to some good paint programs you can try the Gimp. It's a free paint program that has some features similar to photoshop.
    Apr 2009
    Davisburg, MI
    Thanks, I tried GIMP. It does have a better tool set than paint, but I'm still getting the same error. All I changed this time from the original was "C" to "PSI". XP says its a PNG, why doesn't MDX recognize it?
    Mar 2006
    Colorado, but Canadian!
    is it "png" or "PNG"
    What sort of transparency? What colour depth? Interlaced?
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2009
    Davisburg, MI
    oilpressure.png-1.0 (RGB, 1 layer) 260x170 Beyond that I'll have to look up what you are talking about.
    Aug 2008
    Decatur Illinois
    I too had that problem. I just saved the image as a .bmp file and it worked fine. I was never able to get the software to accept a png file no matter where I created it. All of my images are .bmp.
    Fred
    Mar 2006
    Well as to software that creates fully compatible png images, I use Adobe Photoshop CS4. Versions CS2/CS3 work fine as well, and I am sure even earlier ones would too, but I have not tested personally.
    Apr 2009
    Davisburg, MI
    Quote Originally Posted by FredWorrell View Post
    Fred
    Thanks, that worked. Have any drawbacks to using bmp's? Still curious why only Adobe png's accepted. Looks like its going to take me a while to figure out the software side of this.
    -Rob
    Mar 2006
    Quote Originally Posted by ACCLR8N View Post
    -Rob
    drawbacks are that you dont have any transparency
    Aug 2008
    Decatur Illinois
    -Rob
    I did not need transparancy with my application, so using bmp files was not a problem.
    Fred
  1. ASRR plugin: advanced support RoadRunner
    By niko73 in forum RR Released Plugins
    Last Post: 06-28-2009, 01:29 PM
  2. Unofficial TouchSense PR-1000 Protocol Description
    By Fiberoptic in forum MP3Car Products - store.mp3car.com
    Last Post: 04-01-2009, 08:36 AM
  3. XM / Sirius Worklog
    By Nola111 in forum Centrafuse
    Last Post: 08-20-2008, 10:05 AM
  4. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 07:12 AM
