Results 1 to 4 of 4
Thread: MDX rotation images?
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    I've been working on my speedometer skin. Now that I have images to put in MDX, my searching has lead me to believe the current version rotation image function doesn't work. Can someone point me in the right direction?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ACCLR8N View Post
    You have to do it manually in the config file, not through the configurator unfortunately.
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2009
    Davisburg, MI
    Anybody have an example of manual rotation code for this?
    Dec 2007
    Yes can we get an example. I found an old example but am not sure where to put it in the code. And it gets over written if I do anything in configurator.
  1. MDX and COM big update
    By 2k1Toaster in forum FB Software
    Last Post: 02-18-2010, 09:43 PM
  2. Rotate Images, Logic Builder, Counters
    By keyvan in forum FB Documentation and Tutorials
    Last Post: 01-13-2009, 04:14 PM
  3. How to use a configuration file created by the Configurator with MDX
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 09-08-2008, 05:36 PM
  4. Quick overview of the Fusion Control Centre MDX Configurator
    Last Post: 06-06-2008, 06:17 AM
  5. Access 2003 help needed
    By veedubya in forum Off Topic
    Last Post: 05-31-2006, 07:49 PM
