Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Customising the look of FuseGL
  1. #21
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    These are the things I need some clarification on for FuseGL:
    Removing the title bar
    Changing Font
    Changing Font colour
    I'm not sure which file would set these (UserGUI or UpdateLabelText) and to be honest, which language I should be trying to learn. Every tutorial I find on C#looks nothing like what's in the UserGUI file, and everything on XML just points to using .ttf fonts which apparently FuseGL can't use.
    I'm only at the "Hello World!" stage of C#, so it'll take me a while to figure all this out for myself.
  2. #22
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Grrrmachine View Post
    Changing Font
    C# is the language to learn. XML is not really a language even though they say it is, it is more of a structure. The cs files are C# files and are anything. The XML files are just settings and mean nothing without C# behind it.
    Here is how you can remove the title bar:
    Code:
    <?xml version="1.0" encoding="utf-8"?>
    <FuseGL_User_Settings>
      <FuseGL_GUI_Settings>
        <TitleBar>
          <setting type="bool" titlebar_always_hidden="true" />
        </TitleBar>
      </FuseGL_GUI_Settings>
    </FuseGL_User_Settings>
    That is just showing you where in the XML to code it, but the main thing is the line:
    Code:
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Sep 2005
    Warsaw, Poland
    Yep, that worked great, thanks Nick. That allows FuseGL to be cleanly embedded within RideRunner.
    I do understand that XML is just a way to store info rather than display it. But, as with the Title Bar, I'm not sure which settings control the font, or which file they should go in.
  4. #24
    Sep 2005
    Warsaw, Poland
    Right, after a month of on-off struggling with this, I've thrown in the towel. I just can't work out how you're supposed to declare the new font, especially in a global way that affects all the labels I'm running. So I'll leave these here and let others play around with them to see if they can find a solution.
    This is the font .png (right-click to see image)
    and the XML for the font:
    Code:
    <?xml version="1.0" encoding="utf-8" ?>
    <font fontImage="HandelGotD.png">
      <char location_topleft="0,0" location_bottomright="10,15" value="97" offsets="0,0,0,0"></char>
      <char location_topleft="16,0" location_bottomright="25,15" value="98" offsets="0,0,0,0"></char>
      <char location_topleft="30,0" location_bottomright="38,15" value="99" offsets="0,0,0,0"></char>
      <char location_topleft="43,0" location_bottomright="52,15" value="100" offsets="0,0,0,0"></char>
      <char location_topleft="58,0" location_bottomright="66,15" value="101" offsets="0,0,0,0"></char>
      <char location_topleft="71,0" location_bottomright="78,15" value="102" offsets="0,0,0,0"></char>
      <char location_topleft="83,0" location_bottomright="92,15" value="103" offsets="0,0,0,0"></char>
      <char location_topleft="98,0" location_bottomright="107,15" value="104" offsets="0,0,0,0"></char>
      <char location_topleft="113,0" location_bottomright="116,15" value="105" offsets="0,0,0,0"></char>
      <char location_topleft="120,0" location_bottomright="126,15" value="106" offsets="0,0,0,0"></char>
      <char location_topleft="132,0" location_bottomright="141,15" value="107" offsets="0,0,0,0"></char>
      <char location_topleft="146,0" location_bottomright="149,15" value="108" offsets="0,0,0,0"></char>
      <char location_topleft="155,0" location_bottomright="168,15" value="109" offsets="0,0,0,0"></char>
      <char location_topleft="174,0" location_bottomright="183,15" value="110" offsets="0,0,0,0"></char>
      <char location_topleft="188,0" location_bottomright="198,15" value="111" offsets="0,0,0,0"></char>
      <char location_topleft="204,0" location_bottomright="213,15" value="112" offsets="0,0,0,0"></char>
      <char location_topleft="218,0" location_bottomright="227,15" value="113" offsets="0,0,0,0"></char>
      <char location_topleft="233,0" location_bottomright="240,15" value="114" offsets="0,0,0,0"></char>
      <char location_topleft="245,0" location_bottomright="254,15" value="115" offsets="0,0,0,0"></char>
      <char location_topleft="259,0" location_bottomright="266,15" value="116" offsets="0,0,0,0"></char>
      <char location_topleft="271,0" location_bottomright="280,15" value="117" offsets="0,0,0,0"></char>
      <char location_topleft="285,0" location_bottomright="295,15" value="118" offsets="0,0,0,0"></char>
      <char location_topleft="300,0" location_bottomright="313,15" value="119" offsets="0,0,0,0"></char>
      <char location_topleft="318,0" location_bottomright="328,15" value="120" offsets="0,0,0,0"></char>
      <char location_topleft="333,0" location_bottomright="342,15" value="121" offsets="0,0,0,0"></char>
      <char location_topleft="347,0" location_bottomright="356,15" value="122" offsets="0,0,0,0"></char>
      <char location_topleft="1,15" location_bottomright="14,30" value="65" offsets="0,0,0,0"></char>
      <char location_topleft="19,15" location_bottomright="30,30" value="66" offsets="0,0,0,0"></char>
      <char location_topleft="35,15" location_bottomright="46,30" value="67" offsets="0,0,0,0"></char>
      <char location_topleft="51,15" location_bottomright="63,30" value="68" offsets="0,0,0,0"></char>
      <char location_topleft="68,15" location_bottomright="79,30" value="69" offsets="0,0,0,0"></char>
      <char location_topleft="84,15" location_bottomright="94,30" value="70" offsets="0,0,0,0"></char>
      <char location_topleft="99,15" location_bottomright="111,30" value="71" offsets="0,0,0,0"></char>
      <char location_topleft="116,15" location_bottomright="128,30" value="72" offsets="0,0,0,0"></char>
      <char location_topleft="134,15" location_bottomright="137,30" value="73" offsets="0,0,0,0"></char>
      <char location_topleft="142,15" location_bottomright="151,30" value="74" offsets="0,0,0,0"></char>
      <char location_topleft="157,15" location_bottomright="168,30" value="75" offsets="0,0,0,0"></char>
      <char location_topleft="173,15" location_bottomright="182,30" value="76" offsets="0,0,0,0"></char>
      <char location_topleft="187,15" location_bottomright="202,30" value="77" offsets="0,0,0,0"></char>
      <char location_topleft="208,15" location_bottomright="219,30" value="78" offsets="0,0,0,0"></char>
      <char location_topleft="225,15" location_bottomright="238,30" value="79" offsets="0,0,0,0"></char>
      <char location_topleft="243,15" location_bottomright="254,30" value="80" offsets="0,0,0,0"></char>
      <char location_topleft="259,15" location_bottomright="272,30" value="81" offsets="0,0,0,0"></char>
      <char location_topleft="277,15" location_bottomright="288,30" value="82" offsets="0,0,0,0"></char>
      <char location_topleft="293,15" location_bottomright="304,30" value="83" offsets="0,0,0,0"></char>
      <char location_topleft="309,15" location_bottomright="320,30" value="84" offsets="0,0,0,0"></char>
      <char location_topleft="325,15" location_bottomright="336,30" value="85" offsets="0,0,0,0"></char>
      <char location_topleft="337,15" location_bottomright="350,30" value="86" offsets="0,0,0,0"></char>
      <char location_topleft="1,30" location_bottomright="17,45" value="87" offsets="0,0,0,0"></char>
      <char location_topleft="22,30" location_bottomright="34,45" value="88" offsets="0,0,0,0"></char>
      <char location_topleft="39,30" location_bottomright="51,45" value="89" offsets="0,0,0,0"></char>
      <char location_topleft="55,30" location_bottomright="67,45" value="90" offsets="0,0,0,0"></char>
      <char location_topleft="72,30" location_bottomright="84,45" value="48" offsets="0,0,0,0"></char>
      <char location_topleft="90,30" location_bottomright="93,45" value="49" offsets="0,0,0,0"></char>
      <char location_topleft="98,30" location_bottomright="109,45" value="50" offsets="0,0,0,0"></char>
      <char location_topleft="114,30" location_bottomright="125,45" value="51" offsets="0,0,0,0"></char>
      <char location_topleft="130,30" location_bottomright="142,45" value="52" offsets="0,0,0,0"></char>
      <char location_topleft="148,30" location_bottomright="159,45" value="53" offsets="0,0,0,0"></char>
      <char location_topleft="164,30" location_bottomright="176,45" value="54" offsets="0,0,0,0"></char>
      <char location_topleft="180,30" location_bottomright="192,45" value="55" offsets="0,0,0,0"></char>
      <char location_topleft="197,30" location_bottomright="209,45" value="56" offsets="0,0,0,0"></char>
      <char location_topleft="214,30" location_bottomright="226,45" value="57" offsets="0,0,0,0"></char>
      <char location_topleft="231,30" location_bottomright="241,45" value="43" offsets="0,0,0,0"></char>
      <char location_topleft="245,30" location_bottomright="252,45" value="45" offsets="0,0,0,0"></char>
      <char location_topleft="256,30" location_bottomright="265,45" value="62" offsets="0,0,0,0"></char>
      <char location_topleft="270,30" location_bottomright="279,45" value="60" offsets="0,0,0,0"></char>
      <char location_topleft="284,30" location_bottomright="287,45" value="46" offsets="0,0,0,0"></char>
      <char location_topleft="293,30" location_bottomright="296,45" value="58" offsets="0,0,0,0"></char>
      <char location_topleft="301,30" location_bottomright="304,45" value="39" offsets="0,0,0,0"></char>
      <char location_topleft="310,30" location_bottomright="316,45" value="34" offsets="0,0,0,0"></char>
      <char location_topleft="322,30" location_bottomright="325,45" value="44" offsets="0,0,0,0"></char>
      <char location_topleft="330,30" location_bottomright="334,45" value="59" offsets="0,0,0,0"></char>
      <char location_topleft="338,30" location_bottomright="348,45" value="61" offsets="0,0,0,0"></char>
    </font>
  5. #25
    Mar 2006
    Grab the update to 505, and then put the "font" tag into whatever "text" node you want, and it will work.
    Code:
    <User_Object type="FuseGL_Object">
        <setting type="string" name="GL - LBL - Sensor - Temperature in Celcius[0,1] - OUTSIDE TEMPERATURE" />
        <image location="internal" path="FuseGL.Configurator.Configurator_IMG_Resources.UserButtonBackground" />
        <text font="HandelGotD" text="(action){FuseGL.ExecuteCode(UpdateLabelText.cs;FuseGL_TextManipulation.InternalFlyCompile_UpdateLabelText;ChangeButtonTextOnVariablePersistant;{$[*].autoVariable___[Sensor - Temperature in Celcius[0,1] - OUTSIDE TEMPERATURE]};{this};0.000;C;)}" />
        <size width="210" height="30" />
        <location x="30" y="60" alignment="left" z="0.0" />
        <setting type="int" border_size="1" />
        <setting type="bool" mouse_cursor_to_hand_on_hover="false" />
        <events>
          <startup action="FuseGL.ExecuteCode" inputArgs="Sensors.cs;FuseGL_Sensors.Sensors;Initialize___TempSensor___Celcius;{FB.AnalogueInput(0.1)};{$[*].autoVariable___[Sensor - Temperature in Celcius[0,1] - OUTSIDE TEMPERATURE]};" outputTo="this.text.text" />
        </events>
      </User_Object>
  6. #26
    Sep 2005
    Warsaw, Poland
    Phenomenal! I was just expecting a snippet of code, not an entire FuseGL update. You're a star!
  7. #27
    Mar 2006
    Glad to help. You just had a few syntax errors in the font file. It took a couple minutes to chop it in and so this makes it easier. Hope you like it.
  8. #28
    Sep 2005
    Warsaw, Poland
    Surprisingly, the XML was generated by the old Fusion MDX - HandelD was an old font I used on a previous project back in the days of v3 brains.
    I'm presuming HandelD is now built in to FuseGL since I don't need the xml or png files in my FuseGL folder for the font to load. If that's the case, does it mean every time I need a new font I'll have to ask you to code it into FuseGL?
  1. Communicating with FB6 without FuseGL?
    By Grrrmachine in forum Fusion Brain
    Last Post: 10-21-2012, 12:19 PM
  2. Variables for FuseGL FB6
    By venfayon in forum FB Software
    Last Post: 10-08-2012, 07:11 PM
  3. FuseGL Manual - Work in Progress
    By Grrrmachine in forum FB Documentation and Tutorials
    Last Post: 06-12-2012, 04:06 PM
  4. Customising OBD window in CF 3
    By Chester in forum Centrafuse
    Last Post: 12-09-2009, 10:30 PM
  5. Customising Destinator Color Scheme
    By Ali_2k in forum GPS
    Last Post: 08-08-2008, 06:04 PM
