Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 76
Thread: Sdk?
  1. #61
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    I'm running on an Intel box with XP, programming in VB2008 Express.
    Try cutting the code down to nothing and adding lines back in one by one to see what command causes the app to die.
  2. #62
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    I'm unable to connect to my FB from my VB code (also VB.net Express : ) but the Fusion Control can. The strange bit is I don't have an entry in my registry where I see some software looking. How does Fusion Control MDX find my Fusion Brain, since I can't seem to find my organic one?
  3. #63
    Aug 2003
    Iowa
    Quote Originally Posted by UniqelyCommon View Post
    Try it with my code. You want the fusion brain code demonstration.
    http://lefebure.com/software/
    The only registry entry I read is one that stores the VID/PID of the connected brains. If you already know what that is (via Device Manager) then you don't have to check the registry to see what is available. In your case, I wonder if it cannot write that stuff to the registry due to a permission issue or something. Or maybe 2k1 released a new driver that plays differently. I've been using a driver from 6 months ago.
  4. #64
    Nov 2008
    Look behind you.
    USB\VID_04D8&PID_000C&REV_0000
    these are the id's I found in device manager, neither work, from my reading I THINK that they are in the right format, but I've been wrong before
    Maybe I should blame Vista? (heard from behind monitors everywhere: "Oooooh....*sigh*")
    I acquired your software earlier (actually, I grabbed the copy of FusionUSB.DLL that I'm using from it : ) and it can't find the registry entry (and thus connect) I've even tried manually placing the id's above in and nada, perhaps there is a different piece of information that I could grab from the device manager? (Ex: guid, or compatible Ids or...?)
    Thanks for the input on this rather...specific and weird problem
    EDIT: Hmm...using this DLL I should also be able to connect to my USB mouse and get a bunch of jarbled data, right?
  5. #65
    Mar 2006
    Colorado, but Canadian!
    If using LibUSB drivers, you must use the libusb files to communicate with the brain.
    If using FusionUSB.dll, you need to install the Fusion Brain with the Microsoft WinUSB drivers which we do not use anymore.
    These drivers do NOT play nice together. You must completely uninstall one before installing the other. And I mean completely or you will get random freezups.
    Vista is not to blame, I am developing for the Fusion Brain on it right now. I also use it on XP and it works just fine.
    I suggest looking here for examples on how to connect: http://www.fusioncontrolcentre.com/M...cationClass.cs
    1.9in x 2.9in -- 47mm x 73mm
  6. #66
    Aug 2003
    Iowa
    I'm still using the FusionUSB.dll and the VID/PID looks like:
    USB\VID_04D8&PID_000C\5&39258cb2&0&1
    Make sure you have the &0&1 on the end.
    Or start using the new drivers, which is a better long term solution.
  7. #67
    Nov 2008
    Look behind you.
    Sooo...this would be the adaptation?
    Code:
    Public Class UCSettingsIO
        <System.Runtime.InteropServices.DllImport("C:\Program Files\Fusion Control Centre Uber MDX Edition\Drivers\libusb0.dll")> <System.Runtime.InteropServices.ComVisible(False)> _
        Public Shared Function usb_init() As Integer
        End Function
        <System.Runtime.InteropServices.DllImport("C:\Program Files\Fusion Control Centre Uber MDX Edition\Drivers\libusb0.dll")> _
        Public Shared Function usb_find_busses() As Integer
        End Function
        Public Shared Function usb_get_busses() As StructFormat
        End Function
        Public Shared Function usb_open(ByRef usb_device) As StructFormat
        End Function
        Public Shared Function usb_get_string(ByRef dev, ByVal index, ByVal langid, ByRef buf, ByVal buflen) As Integer
        End Function
    Or am I way off?
    To use libusb-win32 in your own programs include the supplied header file usb.h, and link against the import library (libraries for GCC, BCC, and MSVC are available)
    (http://libusb-win32.sourceforge.net/)
    I don't think these or the
    Code:
    using LibUsbDotNet;
    using LibUsbDotNet.Usb;
    using LibUsbDotNet.Usb.Main;
    used in the example file (THANK YOU) are VB.net friendly, just for C++/C#.net right?
  8. #68
    Mar 2006
    Code:
        End Function
        End Function
        End Function
        End Function
        End Function
    Or am I way off?
    Code:
    using LibUsbDotNet;
    LibUSBDotNet is .NET friendly. VB.NET and C# compile to the same thing.
    LibUSB win32 is C++/VB friendly.
  9. #69
    Nov 2008
    Look behind you.
    in a typical install I'm assuming the LibUSBDotNet file is:
    C:\Program Files\Fusion Control Centre Uber MDX Edition\Configurator\LibUsbDotNet.dll
  10. #70
    Mar 2006
    It is both there and in MDX's folder.
    It is not installed to the system location, so basically the program folder can be copy/pasted to a new computer and still work, assuming you have the dependencies installed.
  1. iGuidance SDK
    By Quattro in forum GPS
    Last Post: 06-23-2006, 07:37 AM
  2. SDK commands over the serial port ????
    By tolisn in forum Road Runner
    Last Post: 12-14-2005, 12:03 PM
  3. Developing Touchscreen SDK -- need feedback!
    By kevlar in forum Software & Software Development
    Last Post: 07-14-2005, 05:55 PM
  4. Replies: 9
    Last Post: 03-31-2005, 02:40 AM
  5. Destinator 3 SDK features working
    By loscooby in forum GPS
    Last Post: 09-21-2004, 12:46 AM
