Results 1 to 5 of 5
Thread: Software v1.6
    Jul 2007
    Software v1.6
    I see that this version comes with a COM object file. Can you give me some examples on how to interface to it and I'll help test?
    Also, how can I add a digital input on a skin. Something that will show the state of the input when I have something connected. This is just for testing, so it can be a simple "on/off" type image. Can you post an example of a skin file?
    How can I log the input values for data logging? It looks like earlier versions wrote that info to the UserConfig.atom file, but that's not used anymore.
    Mar 2007
    manchester, UK
    Quote Originally Posted by ginigma View Post
    i am no expert, but to test my digital inputs i created a digital output and linked the input to the output. my skin then showed me when it recieved a signal.
    Mar 2006
    Colorado, but Canadian!
    In the next upcoming version I will be unlocking the debug interface.
    More details will be provided upon its release, but basically it will show the status of everything. This is the raw screen with no byte stream going in (obviously as Vista wont let me communicate with it yet! )
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2007
    Log file?
    Thanks for the debug info.
    How do I turn logging on? I haven't been able to figure that out. I thought I saw mention where a file (folder?) would be created with the sensor name, but I don't see that happening on my system.
    Mar 2006
    I'm not sure if I answered you in a PM or not, but to turn on data logging now you use the graph button. When the graph button is on, then it logs the data.
    Also you might have some input on this thread: http://www.mp3car.com/vbulletin/soft...ml#post1113500
  1. New system - What software do you all use... what should I put on mine?
    By dsj1979 in forum Software & Software Development
    Last Post: 11-19-2006, 04:16 PM
  2. AutoTap used to develop custom software!
    By Dodger1417 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-25-2006, 11:51 AM
  3. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 05:36 PM
  4. Mediacar V1.6
    By coyote in forum MediaCar
    Last Post: 11-11-2003, 12:07 PM
  5. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
