Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Fusion Brain Data Logging
    Mar 2006
    Colorado, but Canadian!
    I am redoing the part of the application that datalogs. It will be spiffy when done.
    My question though is what do you want to be able to log? Obviously the time the data was taken, and the value for each sensor, but anything else?
    1.9in x 2.9in -- 47mm x 73mm
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Is there really anything else to log?
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
    Mar 2006
    Quote Originally Posted by inh View Post
    I don't believe so... But wanted to get opinions.
    Perhaps the minimum, maximum, and average values or something would be useful. Im just throwing out ideas here.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yea, it's ususally easier or better to add everything while your doing a section/function than it is to go back and add it latter...
    Besides all the sensor value's, min, max, and avg, I think that should cover just about everything...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Mar 2006
    Teaser picture
    Mar 2006
    It is not done yet. I would say 50% functional. But the main stuff is there. Obviously the dates are incorrect. as they were just random testing numbers.
    Logs will now be stored in *.xml format and easily readable in Flash, through a *.xsl guide, or any webpage. Say hello to remote logging.
    Unfortuneatly, because of the way FF reads xml files, I have not been able to get it to work. I need to remove all the whitespace in the xml i believe, but for now, it is all done through ActiveX. The sucky part of this, is that ActiveX is only available on Microsoft Internet Explorer. Not FF. So as of now this does not work in FF, but as it is my browser of choice, I will eventually get it to work. I have never worked with xml reading before. Also it is all javascript run so you need java. Since I think it is a good assumption most of your PCs dont run php/mysql servers locally, I had to do it all "client" side which means javascript.
    I have a few more ideas up my sleeve... Stay tuned.
    Opinions and criticism welcome.
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Sounds cool, looks cooler =]
    I was just thinking, exporting to .csv would be nice too so users could play with the numbers manually in excel or something =]
    Mar 2006
    Well the reason for xml was that I thought all Office products can read xmls quite readily as well as pretty much anything nowadays...
    ill think about adding in a comma seperated output file. The thing is, the more read/write cycles to the harddrive, the more time per iteration, more cpu cycles, slower. Now I am not worried for any of my machines, but I am not too sure about how much a m10k can handle.
    Well anyways, I'm off to bed.
    Keep the suggestions rollin'!
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Add an option to either output csv or xml, or an option to spit out csv values from the xml after the fact with a lil button, so only those people that want it can use it =] Of course, make a way to spit it out without having to press it, via a window message command or something, in case we wanna automate it
    Aug 2006
    Central PA
    Quote Originally Posted by 2k1Toaster View Post
    Teaser picture
    Seriously, that is amazing. Great job on the progress so far! I really like the way thing are laid out along with the color selection.
  1. Renault "Tuner List" Head Unit/CD changer hacking - Controls
    By Vicne in forum Hardware Development
    Last Post: 12-31-2011, 05:58 AM
  2. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  3. using fusion brain to delay turn on of amp
    By theheel in forum Fusion Brain
    Last Post: 08-27-2007, 10:33 PM
  4. Fusion Brain Integration
    By michael2 in forum RR Plugins
    Last Post: 08-22-2007, 12:59 AM
  5. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
