Results 11 to 20 of 29
Thread: **NEW BETA Software release for XP & Vista**
  1. #11
    Aug 2006
    I've been having some issues installing the drivers. I emailed you at the address in the Readme.txt.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ctsoccer13 View Post
    If you are on an XP system, sometimes it likes to see [ClassInstall32] in the inf near the end. Try that and see if it installs.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Aug 2006
    It installs with that, but then I get the error "This device cannot start. (Code 10)"
  4. #14
    Mar 2005
    try unplugging and replugging the device several times.
    This Code 10 has come up once before.. are you Jan?
  5. #15
    Aug 2006
    Jan? No, I'm not Jan.
  6. #16
    Mar 2005
    okay, then that is two people out of about 60 orders with this issue.
    the trouble is, "Jan" returned her board to us, and it worked fine... so I'm not sure what the difference is.
    Are you plugging it into a USB 2.0 port? Did you try unplugging/replugging several times?
  7. #17
    Aug 2006
    I plugged and unplugged the USB cable from the motherboard nearly 10 times and each time I got a "USB device not recognized" popup. When I clicked on it, it took me to the device properties of this "Unknown Device", where it said there are no drivers installed.
    When I tried to install the drivers on that screen, it said they contained no information about the hardware.
    No clue what could be wrong... but thanks for the help thusfar!
  8. #18
    Mar 2006
    Could you try a different computer or a different USB cable?
  9. #19
    Aug 2006
    I plugged it into my laptop and it worked fine when I installed the drivers.
    So, I dont know... what would be missing on my nLited XP that would cause it? Any ideas?
  10. #20
    Mar 2006
    Things that I know are 100%. required:
    .NET 2.0
    Winusb.dll
    Winusb.sys
    Support for driver coinstallers
    I'm glad the hardware is working for you though!
    I suggest a search of your windows folder for anything containing "winusb"
  1. Archive
    By Bitoholic in forum Mobile Media Center
    Last Post: 09-21-2006, 06:59 PM
  2. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  3. The BIGGEST CF Beta Problem "Invalid License"
    By Hwonder in forum CF Bug Reports
    Last Post: 05-21-2006, 04:20 PM
  4. Alpha Release: XMPC-CAR for XM
    By gork in forum Software & Software Development
    Last Post: 01-11-2006, 01:19 PM
  5. dvd issues under release 2.3.2 Beta 2
    By samuelellis in forum Media Engine
    Last Post: 11-12-2005, 11:16 AM
