Page 2 of 32 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 313
Thread: Fusion Control Centre Uber Edition -- Need Testers
  1. #11
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Wow! This new version seems like it has many new awesome and useful features! I already can't get myself away from it trying to figure out the new skinning and programming.
    Question: How do code a PAGE button? Also do the "button id"s matter what they are called?
    Also no matter how you type you button text it always comes out all lower case in the program
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by bratnetwork View Post
    comme ca:
    Code:
    <button id="IncrementPage" enabled="yes" function="change page" functionTargetID="RequiredFiller" vote_opinion="+1" vote_priority="medium">
    the voteopinion again can be either a number (like change to page 2) or it can be a change (like go to next page, or go to the 2nd next page). And the pages work in my version that is new as of like 6am, but not the one for download. So right now page buttons do nothing in your version. I will update it again in a few hours after some curried chicken and roti. yummmmmm
    And the button ID's absolutely have to be unique. If it is not unique, the button will not be added. The only thing it is used for is tying in logic commands to the state of a button rather than an input, as well as internally to decide what button has been clicked.
    Yeah I noticed that too. Easy fix. I made everything convert to lower case so that "functionTargetID" is the same as "functiontargetid" and "FuNcTiOnTaRgEtId". Less typos due to case.
    Also for future reference, I dont get an email when you edit a post. I only get one when you make a new post. So if you are editing your post to add more info, do the post whore thing and make a new post so I get an email. Thanks.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    comme ca:
    Code:
    I saw what you posted in comments/suggestions, and I agree with you on the code tags!
    Just keep us updated on what will end up being case-sensative and what will not please.
    Post-whore it is then...
    Can you explain the following section of code from the beginning of your <all statements> section?
    I'm not sure I'm getting it fully.
    Code:
    <if priority="medium" fire_on="logic">
       <parameter1>
          <variable do="set" name="is5greaterthan3">
             <if>
                <parameter1>
                   <number>5</number>
                </parameter1>
                <test check="greater than or equal to"></test>
                <parameter2>
                   <number>3</number>
                </parameter2>
             </if>
          </variable>
       </parameter1>
       <test check="NAND"></test>
          <parameter2>
             <boolean_operation type="NOT">
                <parameter1>
                   <boolean_operation type="OR">
                      <parameter1>
                         <variable do="get">is5greaterthan3</variable>
                      </parameter1>
                      <parameter2>
                         <boolean>false</boolean>
                      </parameter2>
                   </boolean_operation>
                </parameter1>
          </parameter2>
    </if>
  4. #14
    Mar 2006
    Ok newest version with Text that is any case, and then the page buttons work along with an update in the sample file. A single button can be on multiple pages by just adding another page attribute somewhere in the button.
    Link to newest download:
    RAR: http://www.fusioncontrolcentre.com/T...er20071122.rar
    ZIP: http://www.fusioncontrolcentre.com/T...er20071122.zip
  5. #15
    Mar 2006
    Quote Originally Posted by h3rk View Post
    Nothing is case sensitive at all right now. Every tag name and attribute is converted to lowercase before parsing what it is. So no matter how you type it comes out all lower case. I removed the lower case conversion for the text so it wont do that for the textprimary, textsecondary, and textdisabled.
    Code:
       <parameter1>
             <if>
                <parameter1>
                   <number>5</number>
                </parameter1>
                <parameter2>
                   <number>3</number>
                </parameter2>
             </if>
          </variable>
       </parameter1>
          <parameter2>
                <parameter1>
                      <parameter1>
                      </parameter1>
                      <parameter2>
                      </parameter2>
                </parameter1>
          </parameter2>
    </if>
    ok it is a big if statement. That entire thing needs to evaluate to true before what will be in the "then" area is evaluated. As of right now, nothing is in the "then" area.
    So here is the equivalence:
    Code:
             <if>
                <parameter1>
                   <number>5</number>
                </parameter1>
                <parameter2>
                   <number>3</number>
                </parameter2>
             </if>
    if(5 >= 3) which obviously evaluates to true, but was done for testing not actual use! Then
    Code:
    </variable>
    Takes whatever inside of it and stores it as a variable with name of "is5greaterthan3". If the variable exists, it will override the current value. If the variable does not exist, it will create it. So in this case the variable "is5greaterthan3" is "true".
    Code:
                      <parameter1>
                      </parameter1>
                      <parameter2>
                      </parameter2>
    this makes the operation "true OR false" because is5greaterthan3 is true and then false is obviously "false". The type is OR which is a logic inclusive OR. Meaning if any input is true, then the output is true. So that expression with "true OR false" evaluates to true.
    Then the big all encasing if says "true NAND true" and the outcome of that is of a medium priority. And there are 4 timers remember, the gui, input, output, and logic. So when the logic timer fires, this if statement is evaluated. If fire_on was "gui" for isntance, then when the logic timer ticks, it would ignore this entire if/then completely.
  6. #16
    Oct 2006
    Las Vegas
    thanks, that clears things up nicely. I'm trying to set up "radio-button" functionality with 6 buttons. The buttons are tied to boolean variables.
    Once I get my radio-button-function statement(s) set up, I should set the encasing statement to fire on gui (because it deals with the graphics)?
  7. #17
    Oct 2006
    Las Vegas
    Concerning the following:
    Now the logic portion is sort of like programming in my own little xml based language. I think it is intuitive. And you can create functions to make the code less repetitive. Each analogue port can store a user settable number of history points too. So an averager of time 0 and time 1, would be to add then and divide by 2 type thing. However averaging over any "n" number of points is built in already.
    and
    Code:
    <parameter1>
       <evaluate function="thermometer">
          <input order="1">
             <analogue id="Outside Temp" time="0"></analogue>
          </input>
       </evaluate>
    </parameter1>
    What is "<input order="1">" for?
    Can I put a variable as the value for the 'time' property?
    How do I average here (can the value be an expression)?
  8. #18
    Mar 2006
    Analogues actually average by themselves already if wanted.
    But time cannot be a variable.
    And input order 1 is because in the cooresponding function, there is an input with an order of 1 as input parameter.
  9. #19
    Oct 2006
    Las Vegas
    I see now, there's that thermometer function xml page in the config file. I'm not sure how that works; the reference to it, as a whole, or the thermometer function itself.
  10. #20
    Mar 2006
    it searches for function that has a matching name. If it finds one, it parses that function. But first it needs to get the inputs to the function. In this case all it does it take the voltage of an input and returns the temperature in celcius. So for each sensor we will have something like that.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 10:42 PM
  3. Remote Control Fusion Brain.
    By alexgray104 in forum Fusion Brain
    Last Post: 09-06-2007, 04:16 AM
  4. Replies: 2
    Last Post: 07-24-2007, 10:11 AM
  5. Replies: 1
    Last Post: 12-03-2005, 09:58 PM
