Page 6 of 32 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 313
Thread: Fusion Control Centre Uber Edition -- Need Testers
  1. #51
    Mar 2006
    Colorado, but Canadian!
    It is basically the variable mod 2 or mod whatever the "greater than or equal to" number is...
    1.9in x 2.9in -- 47mm x 73mm
  2. #52
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    thanks 2k1Toaster! worked flawlessly!
  3. #53
    Mar 2006
    Awesome.
    Just keep in mind that the program evaluates top to bottom, so you probably want to make all your "variable modulo" commands at the top or at the very least before the if statement of the area that needs it.
  4. #54
    Mar 2006
    Fun with unsafe coding and generic pointers... I think my math is off somewhere. It should just be a second needle rotated a bit
  5. #55
    Oct 2006
    Las Vegas
    It looks like your new needle is on an 80's scrambled TV channel
    Not that I used to stare at that channel for hours on end, as a kid.
  6. #56
    Mar 2006
    I dont even know how I got white pixels... Oh, well time to try again.
  7. #57
    Mar 2006
    Ok, well I finally got what I wanted to do to work, but it is very slow. Almost 200ms for 90degree rotation. So obviously that wont do. It has to do with the way GDI draws, so for now, I suppose multiimage is the way to go unless I start to muck around with DirectX, which would suck big time.
  8. #58
    Mar 2006
    Alright, new version. The changes are one Page #1 (2nd page).
    Basically all the code is in there now for logging. Currently no "nice" way to view the logged info, but it loggs, and notepad or any webbrowser can open the file, it just wont be of much help right now.
    RAR: http://www.fusioncontrolcentre.com/T...er20071202.rar
    ZIP: http://www.fusioncontrolcentre.com/T...er20071202.zip
    And here is the newest source with everything:
    RAR: http://www.fusioncontrolcentre.com/T...ce20071202.rar
    This new version also includes the code for the rotate image with "streak" which is what slowed the computer down big time. Thing is I am trying to get a look similar to some japanese cluster displays which use semi-circular gradients instead of a needle. It works, but is slow. Unfortuneatly, GDI+ is no good at pixel level manipulations, so that means I will need to enter the world of DirectX coding. Not really worth it to me right now. If this is something you guys want though, then I will give it a try late December when I get some free time.
    Let me know if you encounter any bugs. This version with the logging makes a lot of calls to the harddrive and IO calls. So it is very possible I missed a handle free call, but I tested it all night/morning and seems to be stable.
  9. #59
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    Sweet, now I can help myself a bit more Or just learn some more.
  10. #60
    Oct 2006
    Las Vegas
    I'm diggin the action on the white needle. Is the plan to be able to apply a gradient across the needle's sweep somehow?
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  2. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 09:42 PM
  3. Remote Control Fusion Brain.
    By alexgray104 in forum Fusion Brain
    Last Post: 09-06-2007, 03:16 AM
  4. Replies: 2
    Last Post: 07-24-2007, 09:11 AM
  5. Replies: 1
    Last Post: 12-03-2005, 08:58 PM
