Page 8 of 32 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 313
Thread: Fusion Control Centre Uber Edition -- Need Testers
  1. #71
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by h3rk View Post
    It seems like the test sweep isn't slowing things down nearly as much as the logger. Turning it off speeds things up immensely. I'm going to hunt it down, but are you writing to file for each data point, as it occurs? If so, could you collect a group of data and dump to file less frequently? Would that be faster?
    yes and yes. I have already planned what code I need to make it dump a list to a file. But if you turn logging off, that sweep still takes forever. Using the debug console I made DateTimes at the start and end, subtracted them and the resulting TimeSpan said it took almost 100ms to 200ms just for 1 image streak rotating...
    1.9in x 2.9in -- 47mm x 73mm
  2. #72
    Oct 2006
    Las Vegas
    I cant see anything that I would think would make it really slower than the time to go through a round of timers up until the using (Graphics) part, I got a little lost there. Ive never used that before. Do you think maybe that angle part could be applied to a solid object (or a mask over it) to get the desired effect?
    I was reading about needing to use clears in a foreach loop, but I'm not sure how that would apply here, if that's needed or not.
  3. #73
    Mar 2006
    The slow part comes with the way that "DrawImage" or "DrawPixel" works internally. They have a ton of clipping algorithms and that is big overhead. I could probably speed it up by double buffering, but I havenot been successful with double buffering in C# as I get flickering, but it is something I am looking into.
    If you do a quick google for "C# DrawImage slow" or something I am sure you can read up on the specifics as to why it is slow...
    That is true for most languages. You are talking about what is usually called "garbage collecting". In C and C++ this is very very important. Pretty much all non-managed code it is important. However, C# is fully managed, and has a fully automatic garbage collector.
  4. #74
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    Wow, that post shows up as #6 on google for "C# DrawImage slow", that's some serious ranking.
  5. #75
    Mar 2006
    wow... an hour to reach in the top 10! We are writing history here!
  6. #76
    Oct 2006
    Las Vegas
    so it seems possible to draw a graph slice from a (or a coupleof) full graph images, perhaps using something like your angle functions just prior to Drawimage, only by defining an area with the angles. That way a gradient could be applied along the path of the arc, even redlines could be defined that way. Redlines could be set by the user, and that portion of the newimage could be drawn from a different source. I like the idea of redrawing only what changes.
  7. #77
    Oct 2006
    Las Vegas
    Have you seen this in regards to fixing buttons' transparent border?
    Problem with Tranaparent GIF's
  8. #78
    Mar 2006
    so anybody get any glitches, or errors or anything? It has been stable for me... If no one says anything over the weekend, this will be the new official release. Well first I have to port the skin over...
  9. #79
    Oct 2006
    Las Vegas
    It's been good for me, no complaints.
  10. #80
    Mar 2006
    I am not sure what you mean... I have set the buttons to have no border. A fully transparent button should have no border.
    Are you talking about the transparent images on top of one an another? I didnt see that mentioned in there. But I have read the solution. Simply, it cannot be done in GDI. Reason being Microsoft lied to everyone. They DO NOT support transparency. What a transparent region does is get the background of the control and paint it where the "transparent" region is. So there is actually no such thing as transparency which is a dirty little trick. Seems like a hack job to me and I have no idea what would make them do that. Maybe some intern with a deadline, I dunno, but it is a horrible little secret they have and should let people know of this more openly instead of advertising transparency support...
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 10:42 PM
  3. Remote Control Fusion Brain.
    By alexgray104 in forum Fusion Brain
    Last Post: 09-06-2007, 04:16 AM
  4. Replies: 2
    Last Post: 07-24-2007, 10:11 AM
  5. Replies: 1
    Last Post: 12-03-2005, 09:58 PM
