Page 9 of 32 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 313
Thread: Fusion Control Centre Uber Edition -- Need Testers
  1. #81
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by h3rk View Post
    It's been good for me, no complaints.
    Cool. Anything that you want to be put in? Within reason.
    1.9in x 2.9in -- 47mm x 73mm
  2. #82
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Quote Originally Posted by 2k1Toaster View Post
    A way to run a timer, then fire certain outputs at certain times while the timer is running. Tried playing with some older source code... Icky! Although I do like some of your variable names. They are silly.
  3. #83
    Mar 2006
    Quote Originally Posted by Arrow View Post
    Cool variable names keep it interesting... Look in the code that evaluates the voltage into an acceleration... "g_string"
    As for the timer, sure. It wont be nearly as accurate as the 1ms you wanted earlier though because it needs to be evaluated in 1 loop cycle and then sent to the output queue in the next loop cycle. So it will be "logic timer interval" + "output timer interval" which currently is about 100ms... Can get it down to like 10ms to 12ms but that is as good as it will get...
  4. #84
    Oct 2006
    Las Vegas
    I'd like the part we were discussing earlier (post 44). That will get me a bit further. Also, a way to do math on variables will help(or some instruction if possible already).
    I am not sure what you mean... I have set the buttons to have no border. A fully transparent button should have no border.
    Are you talking about the transparent images on top of one an another? I didnt see that mentioned in there. But I have read the solution. Simply, it cannot be done in GDI. Reason being Microsoft lied to everyone. They DO NOT support transparency. What a transparent region does is get the background of the control and paint it where the "transparent" region is. So there is actually no such thing as transparency which is a dirty little trick. Seems like a hack job to me and I have no idea what would make them do that. Maybe some intern with a deadline, I dunno, but it is a horrible little secret they have and should let people know of this more openly instead of advertising transparency support...
    Actually I've been working really hard to accomplish this in various ways and present an example of the 'build arc image from 2 polygons,as determined by the angle' process I was talking about; but I see what you mean, everything I try doesn't work. Everything I've read about have been cumbersome tricks of one form or another, setting pixels or redrawing whats underneath on the graphic and whatnot.
    So, overlapping will look ok as long as it's only overlapping a transparent portion of the under-image, and the height of the image is determined by the order put in the configuration file? I suppose trial and error will be how to determine which image type(button, multi,rotate) is 'higher'
    What's the preffered type to use for non-functional images? Disabled buttons?
  5. #85
    Feb 2006
    West Lafayette, IN
    I just need it to be accurate enough to make the lights flash to the music. I really don't need 1ms accuracy, I was just throwing that out for an example. It doesn't even need to be all that accurate, just as long as it looks good
  6. #86
    Oct 2006
    Las Vegas
    Oh yeah, stretch options on mulitimages and buttons.
  7. #87
    Mar 2006
    Ok, Display buttons, Rotate Images, and MultiImages can now scale the image...
    Code:
    <options imageScaling="stretch"></options>
    and all the options are "stretch", "centre", "tile", "zoom" (I dont even know what this does, but it is an option for ImageLayout)
  8. #88
    Oct 2006
    Las Vegas
    My slide rule thanks you.
  9. #89
    Feb 2006
    West Lafayette, IN
    timer...
  10. #90
    Mar 2006
    timer...
    I am working on it!
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 10:42 PM
  3. Remote Control Fusion Brain.
    By alexgray104 in forum Fusion Brain
    Last Post: 09-06-2007, 04:16 AM
  4. Replies: 2
    Last Post: 07-24-2007, 10:11 AM
  5. Replies: 1
    Last Post: 12-03-2005, 09:58 PM
