Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 51
Thread: problem with uber xna
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Are you running a 64 bit OS?
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Mar 2006
    Also, by using that info, I have been digging around, and it seems both DirectX 9.0c and XNA redistributables have to be installed at a minimum.
    So I am thinking you are missing this if you have already downloaded and installed the XNA redistributable: http://www.microsoft.com/Downloads/d...displaylang=en
    I will be making an installer next month hopefully that will do this automatically. I havent yet been able to reproduce this error at all on my PC, so it is long-distance debugging only I'm afraid.
  3. #23
    Oct 2006
    Las Vegas
    he's got the following installed
    Microsoft .NET Framework 2.0
    Microsoft DirectX SDK (November 2007)
    Microsoft XNA Framework Redistributable 2.0
    from what I've got from talking to him
    He's getting the same exact error (found in event viewer) that I got before I downloaded the DirectX SDK
  4. #24
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    Quote Originally Posted by 2k1Toaster View Post
    im using winxp home sp2 not sure maybe 32 bit
  5. #25
    Oct 2006
    Las Vegas
    uh oh, I sent my copy over to my xp sp2 car pc that we talked about in the other thread (for testing), and ....
    Yep,
    I'm getting the same error.
    Event Type: Error
    Event Source: .NET Runtime 2.0 Error Reporting
    Event Category: None
    Event ID: 1000
    Date: 1/21/2008
    Time: 11:37:21 PM
    User: N/A
    Computer: AUTOIC-MOBILE
    Description:
    Faulting application fusion control centre uber xna edition.exe, version 2.1.0.0, stamp 478b2fc8, faulting module kernel32.dll, version 5.1.2600.3119, stamp 46239bd5, debug? 0, fault address 0x00012a5b.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Data:
    0000: 41 00 70 00 70 00 6c 00 A.p.p.l.
    0008: 69 00 63 00 61 00 74 00 i.c.a.t.
    0010: 69 00 6f 00 6e 00 20 00 i.o.n. .
    0018: 46 00 61 00 69 00 6c 00 F.a.i.l.
    0020: 75 00 72 00 65 00 20 00 u.r.e. .
    0028: 20 00 66 00 75 00 73 00 .f.u.s.
    0030: 69 00 6f 00 6e 00 20 00 i.o.n. .
    0038: 63 00 6f 00 6e 00 74 00 c.o.n.t.
    0040: 72 00 6f 00 6c 00 20 00 r.o.l. .
    0048: 63 00 65 00 6e 00 74 00 c.e.n.t.
    0050: 72 00 65 00 20 00 75 00 r.e. .u.
    0058: 62 00 65 00 72 00 20 00 b.e.r. .
    0060: 78 00 6e 00 61 00 20 00 x.n.a. .
    0068: 65 00 64 00 69 00 74 00 e.d.i.t.
    0070: 69 00 6f 00 6e 00 2e 00 i.o.n...
    0078: 65 00 78 00 65 00 20 00 e.x.e. .
    0080: 32 00 2e 00 31 00 2e 00 2...1...
    0088: 30 00 2e 00 30 00 20 00 0...0. .
    0090: 34 00 37 00 38 00 62 00 4.7.8.b.
    0098: 32 00 66 00 63 00 38 00 2.f.c.8.
    00a0: 20 00 69 00 6e 00 20 00 .i.n. .
    00a8: 6b 00 65 00 72 00 6e 00 k.e.r.n.
    00b0: 65 00 6c 00 33 00 32 00 e.l.3.2.
    00b8: 2e 00 64 00 6c 00 6c 00 ..d.l.l.
    00c0: 20 00 35 00 2e 00 31 00 .5...1.
    00c8: 2e 00 32 00 36 00 30 00 ..2.6.0.
    00d0: 30 00 2e 00 33 00 31 00 0...3.1.
    00d8: 31 00 39 00 20 00 34 00 1.9. .4.
    00e0: 36 00 32 00 33 00 39 00 6.2.3.9.
    00e8: 62 00 64 00 35 00 20 00 b.d.5. .
    00f0: 66 00 44 00 65 00 62 00 f.D.e.b.
    00f8: 75 00 67 00 20 00 30 00 u.g. .0.
    0100: 20 00 61 00 74 00 20 00 .a.t. .
    0108: 6f 00 66 00 66 00 73 00 o.f.f.s.
    0110: 65 00 74 00 20 00 30 00 e.t. .0.
    0118: 30 00 30 00 31 00 32 00 0.0.1.2.
    0120: 61 00 35 00 62 00 0d 00 a.5.b...
    0128: 0a 00 ..
  6. #26
    Oct 2005
    Event Type: Error
    Event ID: 1000
    Date: 1/22/2008
    Time: 2:49:23 AM
    User: N/A
    Computer: HINFAMILY
    Description:
    Data:
    0128: 0a 00 ..
  7. #27
    Oct 2006
    Las Vegas
    it seems that this version is the most recent one that works on my XP computer.
    Fusion Control Centre Uber Edition -- Need Testers
  8. #28
    Oct 2005
    Event Type: Error
    Event ID: 5000
    Date: 1/19/2008
    Time: 3:45:25 PM
    User: N/A
    Computer: HINFAMILY
    Description:
    EventType clr20r3, P1 ifuagtl325w1tyk2sqi42w30bbptcjsf, P2 2.1.0.0, P3 478b2fc8, P4 microsoft.xna.framework.game, P5 2.0.0.0, P6 474dd5b0, P7 12f, P8 9e, P9 njpadyxeqiebvhz5waqljbousqcz2x5l, P10 NIL.
    Data:
    0000: 63 00 6c 00 72 00 32 00 c.l.r.2.
    0008: 30 00 72 00 33 00 2c 00 0.r.3.,.
    0010: 20 00 69 00 66 00 75 00 .i.f.u.
    0018: 61 00 67 00 74 00 6c 00 a.g.t.l.
    0020: 33 00 32 00 35 00 77 00 3.2.5.w.
    0028: 31 00 74 00 79 00 6b 00 1.t.y.k.
    0030: 32 00 73 00 71 00 69 00 2.s.q.i.
    0038: 34 00 32 00 77 00 33 00 4.2.w.3.
    0040: 30 00 62 00 62 00 70 00 0.b.b.p.
    0048: 74 00 63 00 6a 00 73 00 t.c.j.s.
    0050: 66 00 2c 00 20 00 32 00 f.,. .2.
    0058: 2e 00 31 00 2e 00 30 00 ..1...0.
    0060: 2e 00 30 00 2c 00 20 00 ..0.,. .
    0068: 34 00 37 00 38 00 62 00 4.7.8.b.
    0070: 32 00 66 00 63 00 38 00 2.f.c.8.
    0078: 2c 00 20 00 6d 00 69 00 ,. .m.i.
    0080: 63 00 72 00 6f 00 73 00 c.r.o.s.
    0088: 6f 00 66 00 74 00 2e 00 o.f.t...
    0090: 78 00 6e 00 61 00 2e 00 x.n.a...
    0098: 66 00 72 00 61 00 6d 00 f.r.a.m.
    00a0: 65 00 77 00 6f 00 72 00 e.w.o.r.
    00a8: 6b 00 2e 00 67 00 61 00 k...g.a.
    00b0: 6d 00 65 00 2c 00 20 00 m.e.,. .
    00b8: 32 00 2e 00 30 00 2e 00 2...0...
    00c0: 30 00 2e 00 30 00 2c 00 0...0.,.
    00c8: 20 00 34 00 37 00 34 00 .4.7.4.
    00d0: 64 00 64 00 35 00 62 00 d.d.5.b.
    00d8: 30 00 2c 00 20 00 31 00 0.,. .1.
    00e0: 32 00 66 00 2c 00 20 00 2.f.,. .
    00e8: 39 00 65 00 2c 00 20 00 9.e.,. .
    00f0: 6e 00 6a 00 70 00 61 00 n.j.p.a.
    00f8: 64 00 79 00 78 00 65 00 d.y.x.e.
    0100: 71 00 69 00 65 00 62 00 q.i.e.b.
    0108: 76 00 68 00 7a 00 35 00 v.h.z.5.
    0110: 77 00 61 00 71 00 6c 00 w.a.q.l.
    0118: 6a 00 62 00 6f 00 75 00 j.b.o.u.
    0120: 73 00 71 00 63 00 7a 00 s.q.c.z.
    0128: 32 00 78 00 35 00 6c 00 2.x.5.l.
    0130: 20 00 4e 00 49 00 4c 00 .N.I.L.
    0138: 0d 00 0a 00 ....
  9. #29
    Mar 2006
    Believe me I am working on this. I was actually just able to reproduce this error thismorning. I wiped clean a computer, and installed fresh out the box so to speak, and so I am now aware of what is happening.
    Event Type: Error
    Event ID: 5000
    Date: 1/19/2008
    Time: 3:45:25 PM
    User: N/A
    Computer: HINFAMILY
    Description:
    This is the nifty helpful area. It has my error message code, memory error, version error, and linking errors. This is what I have wanted since you posted an actual picture of your screen.
    The "cl20r3" is something I can use, and points me towards before the application starts. So the program itself isnt erroring. The framework underneath is erroring. .NET is just being initialized, and drawing the assemblies it needed. So this is all underneath code problems which also goes along with the reason why h3rk had errors as well until he installed a bunch of stuff.
    This bunch of stuff, is what I am exploring now. From what I have discovered there is a SP1 for .NET 2.0 that might be required. I am currently making an installer right now to help you out. It is a bit ahead of schedule right now, and I am getting the same error you are on my fresh computer, so it is finally debuggable on my end.
  10. #30
    Oct 2005
    cool, thanks alot
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
