Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: problem with uber xna
  1. #31
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by h3rk View Post
    it seems that this version is the most recent one that works on my XP computer.
    Fusion Control Centre Uber Edition -- Need Testers
    that works somewhat, but I get this on top of the program in a small window
    Unhandled exception has occurred in our application. If you click contionue, the application will ignore this error and attempt to continue. it says'' specified cast is not vaild".
    this is the version uber20071215: im using wxp home sp2 :
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.InvalidCastException: Specified cast is not valid.
    at Fusion_Control_Centre_Uber_Edition.MainForm.IfThen Evaluator(XmlNode input, String typeinput)
    at Fusion_Control_Centre_Uber_Edition.MainForm.Perfor mLogicCommands(String which_timer)
    at Fusion_Control_Centre_Uber_Edition.MainForm.LogicT imer_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Assembly Version: 1.0.1.6282
    Win32 Version: 1.0.1.0
    CodeBase: file:///C:/Documents%20and%20Settings/Owner/Desktop/Uber20071215/Fusion%20Control%20Centre%20Uber%20Edition.exe
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  2. #32
    Mar 2006
    Colorado, but Canadian!
    http://www.fusioncontrolcentre.com/T...aller_v1.0.exe
    There you go. Download and install that. If it errors, then put "-debug" in the shortcut path and it will protect the code, and tell you the error.
    1.9in x 2.9in -- 47mm x 73mm
  3. #33
    Oct 2005
    east coast
    Quote Originally Posted by 2k1Toaster View Post
    how to I do that if I have errors. What shortcut path? this is the error report from mt event viewer: Event Type: Error
    Event Source: .NET Runtime 2.0 Error Reporting
    Event Category: None
    Event ID: 5000
    Date: 1/21/2008
    Time: 11:28:33 AM
    User: N/A
    Computer: HINFAMILY
    Description:
    EventType clr20r3, P1 ifuagtl325w1tyk2sqi42w30bbptcjsf, P2 2.3.0.0, P3 47996861, P4 microsoft.xna.framework.game, P5 2.0.0.0, P6 474dd5b0, P7 12f, P8 9e, P9 njpadyxeqiebvhz5waqljbousqcz2x5l, P10 NIL.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Data:
    0000: 63 00 6c 00 72 00 32 00 c.l.r.2.
    0008: 30 00 72 00 33 00 2c 00 0.r.3.,.
    0010: 20 00 69 00 66 00 75 00 .i.f.u.
    0018: 61 00 67 00 74 00 6c 00 a.g.t.l.
    0020: 33 00 32 00 35 00 77 00 3.2.5.w.
    0028: 31 00 74 00 79 00 6b 00 1.t.y.k.
    0030: 32 00 73 00 71 00 69 00 2.s.q.i.
    0038: 34 00 32 00 77 00 33 00 4.2.w.3.
    0040: 30 00 62 00 62 00 70 00 0.b.b.p.
    0048: 74 00 63 00 6a 00 73 00 t.c.j.s.
    0050: 66 00 2c 00 20 00 32 00 f.,. .2.
    0058: 2e 00 33 00 2e 00 30 00 ..3...0.
    0060: 2e 00 30 00 2c 00 20 00 ..0.,. .
    0068: 34 00 37 00 39 00 39 00 4.7.9.9.
    0070: 36 00 38 00 36 00 31 00 6.8.6.1.
    0078: 2c 00 20 00 6d 00 69 00 ,. .m.i.
    0080: 63 00 72 00 6f 00 73 00 c.r.o.s.
    0088: 6f 00 66 00 74 00 2e 00 o.f.t...
    0090: 78 00 6e 00 61 00 2e 00 x.n.a...
    0098: 66 00 72 00 61 00 6d 00 f.r.a.m.
    00a0: 65 00 77 00 6f 00 72 00 e.w.o.r.
    00a8: 6b 00 2e 00 67 00 61 00 k...g.a.
    00b0: 6d 00 65 00 2c 00 20 00 m.e.,. .
    00b8: 32 00 2e 00 30 00 2e 00 2...0...
    00c0: 30 00 2e 00 30 00 2c 00 0...0.,.
    00c8: 20 00 34 00 37 00 34 00 .4.7.4.
    00d0: 64 00 64 00 35 00 62 00 d.d.5.b.
    00d8: 30 00 2c 00 20 00 31 00 0.,. .1.
    00e0: 32 00 66 00 2c 00 20 00 2.f.,. .
    00e8: 39 00 65 00 2c 00 20 00 9.e.,. .
    00f0: 6e 00 6a 00 70 00 61 00 n.j.p.a.
    00f8: 64 00 79 00 78 00 65 00 d.y.x.e.
    0100: 71 00 69 00 65 00 62 00 q.i.e.b.
    0108: 76 00 68 00 7a 00 35 00 v.h.z.5.
    0110: 77 00 61 00 71 00 6c 00 w.a.q.l.
    0118: 6a 00 62 00 6f 00 75 00 j.b.o.u.
    0120: 73 00 71 00 63 00 7a 00 s.q.c.z.
    0128: 32 00 78 00 35 00 6c 00 2.x.5.l.
    0130: 20 00 4e 00 49 00 4c 00 .N.I.L.
    0138: 0d 00 0a 00 ....
  4. #34
    Mar 2006
    Just like any application. The shortcut that points to the program whether it be on the desktop, in the start menu, or you make a new one, open it up, and after the "C:/...Uber.exe" put "-debug" with the quotes. The path will be quotes.
  5. #35
    Oct 2005
    east coast
    Okay, I made a shortcut on desktop, I still dont understand about where you put ''-debug'' at. when I double click on the desktop icon, I just get an error message like always. this whole fusion brain is very frustrating to me. All I wanted to do is use my steering wheel to control my volume and tracks. I guess Im just going to have to use my air wireless mouse which does what I need it to do all the time. It SEEM THAT NONE OF THE PROGRAMS EVEN WORKS! Im not a programmer, there should be some kind of basic instructions with the software.
  6. #36
    Mar 2006
    Quote Originally Posted by customaudioman View Post
    Version #2 is 100% complete, functional, and error free. If you do not want the newest version then you can use that.
    Uber is still in beta. There are issues. It installs on my machine and a few others that I have tried. I just got the error you are receiving for the first time the other day. Beta testing is not for everyone. It is pretty much completely out of beta now, with the advent of the installer. I just have to add some more error catching and it will be done.
    As to getting the new error code, right click the shortcut, choose properties. There will be a box with a path to the program. Just like adding testmode to Streetdeck. You add debug to this.
    You are free to use to whatever you want, but getting it to work is not hard, and is proven by many customers. I can offer help and am trying to do and will continue to try and help you. The advanced features of the Uber edition is the reason I suggest it over version 2. But a beta release cannot be compared to a non-beta release in stability for any program. And documentation should be available very soon. Until then I have been answering questions timely both here on mp3car, and through emails at the store.
    Anyways, when you add debug like in the picture, if it errors, you will get 2 message boxes. The first will be where it errored. Main-block, Pre-main block, Config, ect.. The second will be a detailed error message as to why.
  7. #37
    Oct 2005
    east coast
    the error reads: microsoft.xna framework. no suitable graphics device exception: couldnt find a direct 3d device that has a direct 3d 9-level driver and support pixel shader 1.1 or greater.
    at MS.XNA.framework.graphics device manager. check for available supported hardware
    change device (boolean force create)
  8. #38
    Mar 2006
    Ok, then it is just as it sounds. Your video card does not support DirectX9 and/or Pixel Shader 1.1. Therefore XNA will not work on that computer period. This lack of support for old/outdated/basic hardware is why I am currently replacing the XNA code with pure OpenGL or DX.
    If you want this working tonight, then you will have to use Version 2.
  9. #39
    Oct 2005
    east coast
    also this installed on my home desktop(intel dg865glc board). In my car I use a micro-atx board which is intel dg965ss board. it has the graphics media accelerator 3000x video(intel gma x3000)
    http://www.intel.com/products/mother...65SS/index.htm will it work with this board? It a pretty new board
  10. #40
    Oct 2005
    east coast
    which one is version 2? can you send me the link to that one to download? thanks
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-30-2006, 11:09 PM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 07:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 10:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-15-2005, 11:10 PM
