Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: problem with uber xna
  1. #41
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by customaudioman View Post
    also this installed on my home desktop(intel dg865glc board). In my car I use a micro-atx board which is intel dg965ss board. it has the graphics media accelerator 3000x video(intel gma x3000)
    http://www.intel.com/products/mother...65SS/index.htm will it work with this board? It a pretty new board
    Well I can see it supports Pixel and Vertex Shaders 3.0 so that is good. The other is DX9, and I see no mention of it, but I have to assume it is supported.
    One last thing you can check is to run this web installer: http://www.microsoft.com/downloads/d...displaylang=en
    which one is version 2? can you send me the link to that one to download? thanks
    Version 2: http://www.fusioncontrolcentre.com/F...&submit+31.y=5
    Version 1.5: http://www.fusioncontrolcentre.com/F...submit+21.y=10
    1.9in x 2.9in -- 47mm x 73mm
  2. #42
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by 2k1Toaster View Post
    here is my hardware graphic card infor:
    -Report Date: 01/24/2008
    Report Time[hr:mm:ss]: 09:48:07
    Driver Version: 6.14.10.3943
    Operating System: Windows NT* 5.1.2600 Service Pack 2
    Default Language: English
    DirectX* Version: 9.0
    Physical Memory: 494 MB
    Min. Graphics Memory: 16 MB
    Max. Graphics Memory: 96 MB
    Graphics Memory in use: 6 MB
    Processor: x86
    Processor Speed: 2593 MHZ
    Vendor ID: 0x8086
    Device ID: 0x2572
    Device Revision: 2
    * Output Devices Connected to Graphics Accelerator *
    Active Monitors:1
  3. #43
    Oct 2005
    east coast
    any ifo on the new program, i had this fusion brain for months and not being able to use it yet. ($70 for this hardware which I cant use) Now to me it seems that the ir steering control would have been better for what I wanted to do. and a anti- amp thump 30sec delay part would have be better. I thought this hardware part would be plug and play. Seems you have to be a programmer, and have a certain hardware for it to even work
  4. #44
    Mar 2005
    The original software (Version 2.x) works fine. I use it every day. It has no unusual hardware requirements that we are aware of.
    We are sorry you are having trouble, but we have tried to help at every step of the way.
    This is a hobbyist level device. It is extremely powerful, but it requires a lot of learning on the end-user's part. Perhaps a 30 second anti thump delay would have been better, but it would not have been nearly as flexible.
    Generally, the more flexible the device, the more complicated it is to use.
  5. #45
    Oct 2005
    east coast
    I download the 2.1 version, it seems to work. But now I need to know where I plug in the x,y info for the steering wheel control? is it in the fusion form dynamic skin file? If it is on what line do I need to put the x,y, info. do I need to rename thing? I using analogue for for steering also. so it going to be input since it the steering wheel control? thanks
    >>MAIN
    #BACKIMAGE#\Black Skin\BlackPixel.bmp|0
    #BACKIMAGE#\Images\BMV2_Background.jpg|1
    #TILESTRETCHBACKIMAGE#TILE
    #SIZE#640;480
    #TRANSPARENT#000255255
    #SYSTEMTRAY#false
    #ANIMATIONINTERVAL#50
    #ANALOGUEINTERVAL#50
    #USESPEECHRECOGNITION#false
    #USESPEECHFULLDICTATION#false
    #SHOWMENUBAR#true
    #SETDEVICEINSTANCE#MyBrain0|USB\VID_04D8&PID_000C\ 5&21ED38B5&0&1
    #SPLITLOGFILE#true
    #SHORTXMLOUTPUT#true
    <<END
    >>OUTPUTS
    #STARTNEW#
    #NAME#Start Car
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#40,170
    #SHOWTEXT#false
    #ANIMATION#{1}::40::0
    #PAGE#0
    #PORT#0
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Defroster
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#142,170
    #SHOWTEXT#false
    #PAGE#0
    #PORT#1
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Fan
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#240,170
    #SHOWTEXT#false
    #PAGE#0
    #PORT#2
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Brights
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#334,170
    #SHOWTEXT#false
    #PAGE#0
    #PORT#3
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Air Conditioner
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#428,170
    #SHOWTEXT#false
    #PAGE#0
    #PORT#4
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Lights
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#521,170
    #SHOWTEXT#false
    #ANIMATION#{1,0}::FOREVER::0
    #PAGE#0
    #PORT#5
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Doors
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#40,296
    #SHOWTEXT#false
    #PAGE#0
    #PORT#6
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Fog Lights
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#142,296
    #SHOWTEXT#false
    #PAGE#0
    #PORT#7
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#4ch Amp
    #TYPE#RELAY
    #DEFAULTSTATE#ON
    #SIZE#90,120
    #LOCATION#240,296
    #SHOWTEXT#false
    #PAGE#0
    #PORT#8
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Oil Slick
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#334,296
    #SHOWTEXT#false
    #PAGE#0
    #PORT#9
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Artillery
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#428,296
    #SHOWTEXT#false
    #PAGE#0
    #PORT#10
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    #STARTNEW#
    #NAME#Missile Launcher
    #TYPE#RELAY
    #DEFAULTSTATE#OFF
    #SIZE#90,120
    #LOCATION#521,296
    #SHOWTEXT#false
    #PAGE#0
    #PORT#11
    #VIDPID#MyBrain0
    #BORDERSIZE#0
    #TIMER#30
    #ENDNEW#
    <<END
    >>AI_INPUTS
    #STARTNEW#
    #NAME#Volume
    #TYPE#POTENTIOMETER
    #VIDPID#MyBrain0
    #MULTILEVELGRAPHICS##0,4.3#\Black Skin\Analogue Graphs\Volume\Bar8.png;\Black Skin\Analogue Graphs\Volume\Bar7.png;\Black Skin\Analogue Graphs\Volume\Bar6.png;\Black Skin\Analogue Graphs\Volume\Bar5.png;\Black Skin\Analogue Graphs\Volume\Bar4.png;\Black Skin\Analogue Graphs\Volume\Bar3.png;\Black Skin\Analogue Graphs\Volume\Bar2.png;\Black Skin\Analogue Graphs\Volume\Bar1.png;\Black Skin\Analogue Graphs\Volume\Bar0.png
    #SIZE#92,144
    #LOCATION#24,19
    #SHOWTEXT#false
    #PAGE#0
    #PORT#0
    #BORDERSIZE#0
    #PLOTLENGTH#100
    #HIGHTHRESHHOLD#d0.05
    #LOWTHRESHHOLD#d-0.05
    #HIGHKEYSEQUENCE#DOWN
    #LOWKEYSEQUENCE#UP
    #HIGHMAINWINDOWTITLE#winamp
    #LOWMAINWINDOWTITLE#winamp
    #ENDNEW#
    #STARTNEW#
    #NAME#Battery
    #TYPE#VOLTAGE
    #VIDPID#MyBrain0
    #MULTILEVELGRAPHICS##0,4.3#\Black Skin\Analogue Graphs\Battery\Bar0.png;\Black Skin\Analogue Graphs\Battery\Bar1.png;\Black Skin\Analogue Graphs\Battery\Bar2.png;\Black Skin\Analogue Graphs\Battery\Bar3.png;\Black Skin\Analogue Graphs\Battery\Bar4.png;\Black Skin\Analogue Graphs\Battery\Bar5.png;\Black Skin\Analogue Graphs\Battery\Bar6.png;\Black Skin\Analogue Graphs\Battery\Bar7.png;\Black Skin\Analogue Graphs\Battery\Bar8.png
    #SIZE#92,144
    #LOCATION#133,19
    #SHOWTEXT#false
    #PAGE#0
    #PORT#1
    #BORDERSIZE#0
    #PLOTLENGTH#100
    #HISTORYSIZE#250
    #ENDNEW#
    #STARTNEW#
    #NAME#Outside Temperature
    #TYPE#VOLTAGE
    #VIDPID#MyBrain0
    #MULTILEVELGRAPHICS##0,4.3#\Black Skin\Analogue Graphs\Temperature\Bar0.png;\Black Skin\Analogue Graphs\Temperature\Bar1.png;\Black Skin\Analogue Graphs\Temperature\Bar2.png;\Black Skin\Analogue Graphs\Temperature\Bar3.png;\Black Skin\Analogue Graphs\Temperature\Bar4.png;\Black Skin\Analogue Graphs\Temperature\Bar5.png;\Black Skin\Analogue Graphs\Temperature\Bar6.png;\Black Skin\Analogue Graphs\Temperature\Bar7.png;\Black Skin\Analogue Graphs\Temperature\Bar8.png
    #SIZE#92,144
    #LOCATION#242,19
    #SHOWTEXT#false
    #PAGE#0
    #PORT#2
    #BORDERSIZE#0
    #PLOTLENGTH#100
    #ENDNEW#
    #STARTNEW#
    #NAME#Engine Temperature
    #TYPE#VOLTAGE
    #VIDPID#MyBrain0
    #MULTILEVELGRAPHICS##0,4.3#\Black Skin\Analogue Graphs\Oil\Bar0.png;\Black Skin\Analogue Graphs\Oil\Bar1.png;\Black Skin\Analogue Graphs\Oil\Bar2.png;\Black Skin\Analogue Graphs\Oil\Bar3.png;\Black Skin\Analogue Graphs\Oil\Bar4.png;\Black Skin\Analogue Graphs\Oil\Bar5.png;\Black Skin\Analogue Graphs\Oil\Bar6.png;\Black Skin\Analogue Graphs\Oil\Bar7.png;\Black Skin\Analogue Graphs\Oil\Bar8.png
    #SIZE#92,144
    #LOCATION#351,19
    #SHOWTEXT#false
    #PAGE#0
    #PORT#3
    #BORDERSIZE#0
    #PLOTLENGTH#100
    #ENDNEW#
    <<END
    >>DI_INPUTS
    #STARTNEW#
    #NAME#Winamp - Play/Pause
    #KEYSEQUENCE#c
    #MAINWINDOWTITLE#winamp
    #PORT#3
    #MINTIMEBETWEEN#500
    #VIDPID#MyBrain0
    #ENDNEW#
    #STARTNEW#
    #NAME#Winamp - Next Song
    #KEYSEQUENCE#b
    #PORT#3
    #MINTIMEBETWEEN#500
    #VIDPID#MyBrain0
    #ENDNEW#
    #STARTNEW#
    #NAME#Winamp - Previous Song
    #KEYSEQUENCE#z
    #PORT#3
    #MINTIMEBETWEEN#500
    #VIDPID#MyBrain0
    #ENDNEW#
    #STARTNEW#
    #NAME#Winamp - Stop
    #KEYSEQUENCE#v
    #PORT#3
    #MINTIMEBETWEEN#500
    #VIDPID#MyBrain0
    #ENDNEW#
    <<END
    >>OTHERBUTTONS
    #STARTNEW#
    #PAGE#0
    #SIZE#160,65
    #LOCATION#456,78
    #ENDNEW#
    #STARTNEW#
    #NAME#+
    #FUNCTION#TIMER_OUT
    #SETTINGS#d10
    **#FUNCTION#PAGE
    **#SETTINGS#1
    #PAGE#0
    #BORDERSIZE#0
    #SIZE#40,37
    #LOCATION#548,36
    #SHOWTEXT#false
    #ENDNEW#
    #STARTNEW#
    #NAME#-
    #FUNCTION#TIMER_OUT
    #SETTINGS#d-10
    **#FUNCTION#PAGE
    **#SETTINGS#0
    #PAGE#0
    #BORDERSIZE#0
    #SIZE#40,37
    #LOCATION#477,36
    #SHOWTEXT#false
    #ENDNEW#
    <<END
    >>DEAD
    <<END
  6. #46
    Oct 2005
    east coast
    okay I figured out where to put the the values from another post. Question is can I rename it steering wheel controls? also for AI Input, to I have too retype another for different controls? Like there is one for volume. But I would still need one for ''next'' and ''previous'' track and and the ''mode'' button?
    example what I need to fill in:
    >>AI_INPUTS
    #STARTNEW#
    #NAME#steering wheel volume ?
    #TYPE#POTENTIOMETER
    #VIDPID#MyBrain0
    #SIZE#92,144
    #LOCATION#24,19
    #SHOWTEXT#false
    #PAGE#0
    #PORT#0
    #BORDERSIZE#0
    #PLOTLENGTH#100
    #HIGHTHRESHHOLD#?
    #LOWTHRESHHOLD#?
    #HIGHKEYSEQUENCE#?
    #LOWKEYSEQUENCE#?
    #HIGHMAINWINDOWTITLE#?
    #ENDNEW#
    also on the program I used before this one, the new that didnt work on my system. I use to value for each button like <3.05><3.55> for the ''mode'' button. what if its not exact voltage, will it still send the key press if its off by little?
  7. #47
    Mar 2006
    Not sure if you want to try Uber MDX, or continue to use version 2. But I thought it would be a good idea to let you know that Uber MDX is 100%
    Here is a link for it: http://www.fusioncontrolcentre.com/T...18-02-2008.rar
    I am not making a thread for it until the configurator is up and running. But there you go.
    And you can run it in the system tray if you want too.
  8. #48
    Oct 2005
    east coast
    I download from the link above. Is that the program? Or do I need to download something else? I have version 2 installed of my system but not uber.
  9. #49
    Mar 2006
    That link is for Uber MDX. All you need is DirectX and it should run. It will be in an installer when it is officially released.
  10. #50
    Oct 2005
    east coast
    I figured it out , I needed to download a .rar program to open the files.
    the program works
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-30-2006, 11:09 PM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 07:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 10:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-15-2005, 11:10 PM
