Page 1 of 6 123456 LastLast
Results 1 to 10 of 51
Thread: problem with uber xna
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    fusion control centre xna 2.1.0.0 error message
    will not open
    Mar 2006
    Colorado, but Canadian!
    What error message?
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    Las Vegas
    crap, I forgot about the extra downloaded stuff needed for the newest versions
    You probably need to use the older version for now. Try putting that configuration file back in the old uber folder and try it.
    Mar 2006
    It should just be the November DirectX SDK that needs downloading...
    Even still, more description for the error is always key.
    Oct 2005
    east coast
    Quote Originally Posted by 2k1Toaster View Post
    so I neeed the november direct x sdk to make the program work?
    Oct 2005
    east coast
    I installed directx sdk(november) same error.
    Oct 2005
    east coast
    I notice in the new version 2.1.0.0 has this written in fusion control centre
    configuration and not in the 1.0.1.0 version. just woundering if this has any thing to do with the program not opening up and get an microsoft error. <font name="Arial100" originalSize="100" font_config="config\fonts\FusionFontArial100.xml"> </font>
    <font name="Arial14" originalSize="14" font_config="config\fonts\FusionFontAri
    the 1.0.1.0 version still works in uber edition
    Mar 2006
    I have no idea what error you are getting so I cannot help. I need to know what error, not that there just is an error.
    When it crashes it will say something. That is the important part here. I cannot tell from here.
    Those fonts are as they say fonts. It allows text to be put on the screen. You can delete those lines, but then no text will show up.
    Seeing as how you say the 1.0.1.0 version works, I am assuming the program runs, just not with the new skin. Well, did you download the whole package and use the new exe as well, or just the skin file? As I said I have absolutely no way of knowing without knowing what error you are getting. If you cannot find the text of the error, take a screenshot and post it here please.
    Oct 2005
    east coast
    the error said problem occurred ; the operating system version and computer hardware in use; your digital product ID, which could be used to identify your license; and the internet protocol(IP)address of your computer. thats all it said. '' fusion control centre xna edition has encountered a problem and needs to close''
    Mar 2005
    Quote Originally Posted by customaudioman View Post
    Please take a screenshot of the error.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
