I have attached one of your relay units and tested it using a multimeter.
I am using the Diag Skin from your skin download Page. Its the last one on the list.
http://www.fusioncontrolcentre.com/F...alog/skins.php
Is there a debug command that can be sent to enable the outputs? 2k1Toaster mentioned that the new versions of FB firmware require that the outputs be enabled each time the values are set.
