Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: If I could only get this thing to work....
    Jan 2008
    Just bought the fusion brain. Installed .net 2.0. Installed hardware drivers 2.0. Grabbed 2.2.1 for Vista and XP. Grabbed the latest skin designer.
    The driver is Da Fusion Brain
    Driver Date: 8/29/2007
    Driver Version 1.0.0.0
    In the skin designer, my brain is displayed when I try to create a new skin. When I click the 'start blinking' option. The program hangs. Ok, after restart, I just just select my brain.
    When I try to add a analog input, I get an assertion failure when I click the add button from the input configuration dialog box.
    When I try to run the Fusion Control Center, I get the following message:
    "There are no Fusion Brain product connected to the computer that are setup in your skin file. ........#SETDEVICEINSTANCE#...."
    From previous forum messages, I tried to specify the ID by configuring that setdeviceinstance file in the skin file. But that field does not exist in the file!
    It there a tutorial project out there? Is there some way to test this card independent of the Fusion Center software?
    Help anyone?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by fermentation View Post
    The skin designer is very finnicky. You must specify all parameters correctly. Unfortunately right now it is hard to know what each parameter is. The skin file needs a "#SETDEVICEINSTANCE#" filed in the Main section (between ">>MAIN" and the first "<<END" in the skin file.
    You may need to add that field. Depending on what version of the skin file you are using and what version of the program you are using, you may just need to add it. Go to device manager, right click on the Fusion Brain, properties. Then Go to driver information, and choose "device instance" or "hardware ID" from the dropdown (depends on XP or Vista) and you should see something like "USB/vid_04d&pid_000c/gf324f23423". Copy that into the skin file as "#SETDEVICEINSTANCE#USB/vid_04d&pid_000c/gf324f23423|MainBrain".
    Help anyone?
    Here is the main skin designer tutorial: http://www.fusioncontrolcentre.com/F...php?tutorial=3
    If the drivers installed correctly, then it should be working just fine. If you are using XP then you can download the old version 1 (Non-Dynamic) version and it should work. This old version is not Vista compatible: http://www.fusioncontrolcentre.com/F...&submit+8.y=15
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2008
    So you had some luck getting the power light to blink? I would have been very pleased to just get that to work.
    Mar 2006
    Power lights? The power light (blue) should not blink...
    The output lights should blink. Are you using XP or Vista?
    And when you click the add brain, there is 1 that shows up correct? If so, then the Brain works.
    Out of curiosity, do you have a little jumper near the bottom of board (by the LED)? There should be one included when you buy it. Without that jumper no output lights will light up.
    Jan 2008
    I am running XP. There is a jumper in place closest to the power light.
    Jan 2008
    Using the non-dynamic version, does the program give any indication that it is connected to a Brain? When I click the digital output buttons, should I see lights change? Will I need to rollback the hardware driver version to get the old software to work?
    Jan 2008
    Ok.. I went back to try the very latest drivers. I opened opened up the new program. I entered the debug console ( click + ctrl + alt + shift + debug, open raw debug ). When I plug in a thermosister into on the analog ports, I get data readings displayed on all of the Analog Inputs visual. Seem to me that this card is busted.
    Thoughts?
    Mar 2006
    Thoughts?
    Nope that is normal. If you are seeing data, then it works!
    If there is nothing connected to the other port, then it "floats". It is highly suggestive to noise when floating. This is ok because if there is nothing attached you wont be monitor it. As soon as you attach a sensor to the input, it no longer floats, and the noise will go away.
    If you want, you can connect a jumper between the sense line and ground on the Brain, which will effectly get rid of that. But like I said, it doesnt matter because you wont be measuring it!
    And to get the previous non-dynamic version to work, yes you need to install version 1 drivers too. But now that you know it works, we should really concentrate on getting the newer version setup.
    Jan 2008
    Are there some schematics available to help me along?
    Mar 2006
    schematic for?
    Here is the preliminary manual with what pins are what are the Brain if that is what you mean: http://www.fusioncontrolcentre.com/F...r%20Manual.pdf
  1. How to make Winamp TV Plugin work with RR
    By ramez75 in forum Road Runner
    Last Post: 09-03-2010, 01:17 AM
  2. How does this reputation thing work?
    By BoyNextDoor in forum Off Topic
    Last Post: 08-20-2006, 07:05 PM
  3. Will a Powermate work with iGuidance?
    By Troy McClure in forum Input Devices
    Last Post: 03-08-2006, 10:55 PM
  4. can't get certain file extensions to work
    By mikemerrill50 in forum Media Engine
    Last Post: 07-09-2005, 05:08 PM
  5. Want to trade website work for a 40 x 4 lcd
    By to_vdubber in forum General MP3Car Discussion
    Last Post: 09-26-2004, 04:30 PM
