Page 12 of 35 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 345
Thread: Uber MDX Configurator Beta Testing...
  1. #111
    Jan 2008
    Texas
    Quote Originally Posted by 2k1Toaster View Post
    Good that you are trying!
    I am sorry I havent been able to get something to you yet, I have had some issues.
    No problem, I fully understand,that you have time to even look at the forums surprises me, I will try to keep my bothering you down to a minimum.
    well then since an if then statement is connected to an output node and I can only have one output node in the logic, I assume that means I add another page of logic for the else stuff, and the order the pages are made is the order the program interprets the logic?
    I Hope the way I worded that it makes sense!!!
    so is an output trigger a state change or is this just a trigger on?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by jimp View Post
    The way it works under the hood is a voting system.
    When you click a button it sends it vote to the queue. When that queue is evaluated, it tallies all the votes in order of priority. So it tallies all high priority votes. If the votes are inconclusive (equal number of change and not change or no high priority votes at all) then it tallies all the medium priority. Again if it is inconclusive, then it tallies all the low votes. If that is inconclusive it does nothing. So If you have 2 buttons 1 that votes yes to turn on and 1 that votes no, and they magically get pressed at the same time and go into the same queue, nothing will happen if their priorities are equal. If 1 is a higher priority than the other, the higher one wins and its vote is cast.
    I promise I will get you a logic module, just give me a bit of time
    1.9in x 2.9in -- 47mm x 73mm
  3. #113
    Mar 2006
    Quote Originally Posted by h3rk View Post
    -Keypad number entries still don't work (have to use the upper row numbers).
    -Static images' display size reset to original size parameters, each time the property window is opened.
    Fixed and fixed.
  4. #114
    Mar 2006
    Quote Originally Posted by ginigma View Post
    Add an Analogue Input dialog box: When adding an analog input, for the Port and History fields, it doesn't accept input from the numeric keypad, only the number keys above the qwerty part of the keyboard work. Similar issue for the Digital Output dialog box.
    Main: When exiting, it should prompt you to save only if the buffer was changed, not all the time.
    Graphical Input/Display Button: I can only enter 4 characters in the Name field, yet when the control loads the first time, you have a longer name there.
    General: When loading/browsing for an image, you bring up a Load Image dialog box, which you have to click the load button again to get to the system Load Image box. Can that intermediary step be eliminated?[/I]
    Fixed
  5. #115
    Oct 2006
    Las Vegas
    Great, uploaded?
    I'm still trying to work out a config file that will run in the version of the main MDX software that I have, starting from scratch, with a background, a static image, and a button, I get errors. When I delete the button, it loads fine. I noticed that the example that comes with the software has no buttons. The only logic related thing I have in the skin is 1 variable that canges via the button.
    Here is a screen captured video I made of me building the skin.. I left out the part where I take off the button and it works. And I already left in the 2 issues you fixed.
    It does seem jimp has built something with the configurator that runs in the MDX software. That's good. I hope I have the right version of the software.
    jimp, do you have buttons?
  6. #116
    Jan 2008
    Texas
    I watched your video, I have been working with the most basics, 1 single button no background, no static images. other than that there is not much difference to yours, when I save mine I just let it over write the file in the MDX-26-03-2008 folder instead of saving to desktop and copying over.
    I am using this MDX program http://www.fusioncontrolcentre.com/T...26-03-2008.rar
    and just unrared it to the desktop, I am using the latest version of the configurator on the first page of this thread.
  7. #117
    Jan 2008
    Texas
    Fixed and fixed.
    I know I told you I would try not to bother you but are you gona share these fixes with us?
  8. #118
    Jan 2008
    Texas
    Not sure if this is because somethings not finished or if its just because I am doing something that I shouldn't be or what, but when I add a variable to logic and save the configuration file, I can open it in the MDX program and it does what it was supposed to do (which aint much, just tinkering with it) but if I close the configurator and then open it and try to open the configuration I saved I get an unhandled exception;
    Code:
    System.NullReferenceException: Object reference not set to an instance of an object.
       at FCC_Uber_MDX_Configurator.GlobalStaticClass.Functions_XMLToModule(XmlNode _node, Module _mod, List`1 _myList)
       at FCC_Uber_MDX_Configurator.GlobalStaticClass.Functions_ParseXMLLogicToDesigner(XmlNode _root, MainMDXConfigForm mom, List`1 inputErrors)
       at FCC_Uber_MDX_Configurator.MainMDXConfigForm.OpenConfigurationFile()
       at FCC_Uber_MDX_Configurator.MainMDXConfigForm.TSB_OpenFile_Click(Object sender, EventArgs e)
       at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
       at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
       at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
       at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
       at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
       at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
       at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.ToolStrip.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.42 (RTM.050727-4200)
        CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    FCC Uber MDX Configurator
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Documents%20and%20Settings/jim/Desktop/MDXConfigBetaNEW/FCC%20Uber%20MDX%20Configurator.exe
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    iFolderComponent
        Assembly Version: 3.6.7085.1
        Win32 Version: 3.6.7085.1
        CodeBase: file:///C:/Program%20Files/iFolder/iFolderComponent.DLL
    Novell.iFolder
        CodeBase: file:///C:/Program%20Files/iFolder/Novell.iFolder.DLL
    System.Web.Services
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
    SimiasClient
        Assembly Version: 1.5.7085.1
        Win32 Version: 1.5.7085.1
        CodeBase: file:///C:/Program%20Files/iFolder/SimiasClient.DLL
    I thought maybe it was because it didn't like that I had logic in the configuration, but I tried it with some simple-stupid stuff like if 1 and 1 equal than trigger output and that opens fine, but if I replace a 1 with a variable then I get the above exception.
  9. #119
    Mar 2006
    Sorry for not posting a bit, I was on a StarCraft fix. Played almost all yesterday into the wee hours of the morning.
    I havent uploaded those fixes yet. I will very soon.
    Also jimp for your error, I have not really tried loading a variable, but I will and see what is going on.
  10. #120
    Mar 2006
    Yup, found the problem. If you do variable-set it works fine. Variable-get will error it becuase I am checking in the wrong order.
    I fixed that.
    Once I get these multiimages done, I will upload a new file.
  1. programing in the Uber Edition.
    By customaudioman in forum Fusion Brain
    Last Post: 02-28-2008, 12:35 AM
  2. Simulating GPS data for testing
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 08-08-2006, 02:16 PM
  3. Testing with standard AC supply
    By rockthevolvo in forum Power Supplies
    Last Post: 08-18-2004, 06:12 PM
  4. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
