Page 2 of 35 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 345
Thread: Uber MDX Configurator Beta Testing...
  1. #11
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Wow, You have been working hard!
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Arrow View Post
    I'd like to think so considering this isnt my full time job
    I have added the ability to delete items now as well. You drag the items from the list area (top left section with big images) into the trashcan (top most menu bar, 3rd icon from the left) and it will delete the object (well it will warn/ask you first) and update the textual area, and eventually the graphics area.
    I am now working on getting the underlying help system up and running. Documentation is a *****!
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Mar 2006
    Also, Tim I am curious if the Brain identifying problem you had is because you were running XP in OSX or not... I have so far only tested on my Vista dev. machine, but it works like a charm here. Once I get the time I will try it on a XP machine though.
  4. #14
    Mar 2006
    Ok, started on the help, this is what it looks like now:
  5. #15
    Mar 2006
    Download link updated.
    You will now see 2 new files called "Help.xml" and "Help.xsd". Those files contain the help documentation so far. So far, help is complete for Adding a Fusion Brain Instance, Digital Output Instance, and Analogue Input Instance.
    If you have suggestions please feel free to let me know.
  6. #16
    Mar 2005
    here
  7. #17
    Feb 2006
    West Lafayette, IN
    Where did you get all these graphics?
  8. #18
    Mar 2006
    Quote Originally Posted by greenman100 View Post
    here
    Well do you have a variable called "my analogue input added" or do you have an analogue input added called that?
    See where it says "type"? Change that to Analogue Input.
  9. #19
    Mar 2006
    I bought a few out of my pocket from istockphoto. Then I used photoshop to delete the icon graphic in the icon background box, and searched with google to find random images and put them in.
  10. #20
    Mar 2005
    I hadn't changed type! woops.
  1. programing in the Uber Edition.
    By customaudioman in forum Fusion Brain
    Last Post: 02-28-2008, 12:35 AM
  2. Simulating GPS data for testing
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 08-08-2006, 02:16 PM
  3. Testing with standard AC supply
    By rockthevolvo in forum Power Supplies
    Last Post: 08-18-2004, 06:12 PM
  4. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
