Page 23 of 35 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 345
Thread: Uber MDX Configurator Beta Testing...
  1. #221
    Oct 2006
    Las Vegas
    I went and edited my multiimages again in configurator, and they didn't default to monitoring an old variable, saving and closing didn't change things either. I can't reproduce it.
    Quote Originally Posted by h3rk View Post
    And...
    is there something to the "pushed" state that has changed? I thought that the image I select in the pushed field is displayed when and only when the button is clicked/pushed.
    I'm still having this problem. In the MDX program.
  2. #222
    Mar 2006
    Colorado, but Canadian!
    I was able to reproduce the problem, so I fixed it. I just uploaded the new exe and the update.xml so if you check for updates, you will get the latest configurator exe.
    And yes the pushed state only is displayed while the mouse is down before it goes up. If you press down on it, but drag out of the button area so when the mouse-up gets registered it isnt in the button area anymore, it could cause it to stick.
    Does it get stuck in the pushed state, or never show the pushed state?
    1.9in x 2.9in -- 47mm x 73mm
  3. #223
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    Update downloaded and installed, and appearantly without a hitch.
    It never shows the pushed state.
  4. #224
    Mar 2006
    I also added the 2nd cancel button to the save form...
  5. #225
    Mar 2006
    Good to know the updater works. It is like long range debugging with that thing!
    I need to get another non-dev machine setup just for installer debugging and updater debugging.
    So does it fix the function opening error as well as the multiimage errors?
    As for the pushed state never showing, I will have to look at it more deeply to refresh myself how I coded that. I am pretty sure that code was a port from XNA. I think DIrectX has a method for checking mouse status, but I have been using the GDI mouse events with the DirectX draw events. Probably not ideal so events may be mismatched and lost... But I think it is DX that does joystick stuff, so it should have mouse/keyboard control. I will see what I can come up with.
    Does the push state never ever show on any of them, or just some that it doesnt work on (like if it is stacked on another image or something).
    I appreciate the feedback from everyone in this thread btw! Really helps to make things happen.
  6. #226
    Mar 2005
    Well word has a Yes/No/Cancel box.
    The has a No/Yes box on the bottom and a Cancel button on the top right (the toolbar close).
    I can try to work in a 2nd cancel button too I suppose...
    You're missing the point.
    Click yes, to save
    then instead of clicking "save", click "cancel". the program quits
  7. #227
    Mar 2006
    Quote Originally Posted by greenman100 View Post
    Click yes, to save
    It is not cancel though. It is "Do Not Save" and "Save" on the bottom. The top right is "Cancel".
    If it was "Save" and "Cancel" on the bottom then how would you exit the program without saving your work? Made a mistake and dont want to save it, you wouldnt be able to because if you didnt save, the program wouldnt close...
  8. #228
    Oct 2006
    Las Vegas
    YES!!!! It does not keep the graphic location of the nodes, but functionally it stayed in-tact. Awesome.
    Nope, even in the sample skin, I've never been able to push a button and see the expected temporary image change. All buttons so far have had this problem for me, on 2 very different computers.
    It's great to see the enthusiastic support. It's rare in my experience, to say the least. It's fun to stroll through the original thread and see just how far things have come. Phidgets eat your heart out.
    But they do have servo and analog out ...
    me-->
  9. #229
    Mar 2005
    arrrg!
    in the dialog box where you type in a file name, if you click cancel, the program exits.
    this is not normal procedure
    does that help?
  10. #230
    Mar 2006
    arrrg!
    does that help?
    Oooooooooooohhh. Ok. I thought you meant the "would you like to save" screen. Where you type in the actual filename is very different.
    Yes it should just cancel. Never really tried it though
  1. programing in the Uber Edition.
    By customaudioman in forum Fusion Brain
    Last Post: 02-28-2008, 12:35 AM
  2. Simulating GPS data for testing
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 08-08-2006, 02:16 PM
  3. Testing with standard AC supply
    By rockthevolvo in forum Power Supplies
    Last Post: 08-18-2004, 06:12 PM
  4. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
