Page 3 of 35 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 345
Thread: Uber MDX Configurator Beta Testing...
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Ok, I have been building up a generic Module class with nodes. The image is what it looks like. Those circles are the nodes for connections between the modules which are the icons. Click the top icon on the bar, the cursor changes to that icon. Click in the graphic panel, and it is placed there with the nodes drawn on automatically and dynamically. So if there is 1 node on the left side, it puts it in them middle. 2 nodes, it puts it at 1/3 and 2/3 and so on. Nodes can be on any side.
    I have it to the point where all I do is make another class that is inherited from the module class, and voila I have a new module to place around and move and such.
    Next thing is to get the node linking working (make output of module A input to module B and then 1 output is the functions output, and then nonconnected nodes are the inputs.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Mar 2006
    Ok, so I have gotten somewhere with the flow layout of the logic portion. Currently it works in the function area for the inputs, output, and boolean operators (except XOR).
    I am trying to get some more tooltips put in to help. Also I am trying to make it build itself so to speak. So I will make all the sensor modules from these basics parts and add them that way.
  3. #23
    Mar 2006
    Ok, download link is updated.
  4. #24
    Mar 2006
    Download Link Updated.
    This time functions can be saved, and imported as new modules for the function layout. So pretty much you can cascade them now.
    Let me know if you have any problems.
  5. #25
    Oct 2006
    Las Vegas
    I alreadyget an error message without even trying... I didn't see any specific, kindergarten level instructions on setup so I thought that I would verify whether I need to do anything other than:
    1) Download the OP linked file, UnRAR it.
    2) Put FCC Uber MDX Configurator.exe, Help.xml, Help.xsd in the main progam folder. (In this case MDX)
    (the 2 dll files appear to be the same between the two folders, and I think that's what you meant in the OP)
    3) Double-click FCC Uber MDX Configurator.exe
    4) ????
    5) Profit
    I think I keep screwing up step 4.
    I get:
    Event Type: Error
    Event Source: .NET Runtime 2.0 Error Reporting
    EventType clr20r3, P1 fcc uber mdx configurator.exe, P2 1.0.0.0, P3 47c7a760, P4 system, P5 2.0.0.0, P6 471ebf0d, P7 36c8, P8 60, P9 system.argumentexception, P10 NIL.
  6. #26
    Mar 2005
    That's really weird, I haven't heard of any troubles with the Configurator.
    I'm sure Nick will be along shortly to help.... sorry!
  7. #27
    Mar 2006
    That is very weird... Maybe the exe is compressed wrong. I will upload a new one tonight
  8. #28
    Dec 2007
    Victoria, Australia
    i get the same error
  9. #29
    Mar 2005
    The newest release crashes for me too, so he probably just needs to recompress/rollback the code.
  10. #30
    Mar 2006
    Link Updated. I didnt compress it as much. Let me know if it works for you guys. The last one was corrupt.
  1. programing in the Uber Edition.
    By customaudioman in forum Fusion Brain
    Last Post: 02-28-2008, 12:35 AM
  2. Simulating GPS data for testing
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 08-08-2006, 02:16 PM
  3. Testing with standard AC supply
    By rockthevolvo in forum Power Supplies
    Last Post: 08-18-2004, 06:12 PM
  4. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
