yes you can use the xml independantly, or you can use the configurator and the xml editor together. It is up to you.
And if the brain is not connected then you have to manually enter the brain id into the box. You can use a placeholder if you want, but your skin file wont work until you edit it manually.
LinkBack URL
About LinkBacks
So you can make it infinately larger and it will continue to scale. Mini-achievement.
