Also, on the left side, the bottom is the realtime textual output of the configuration file and the top left is the editing area. The things that only have 1 "instance" such as properties (your name, size of the application) can be edited by the top menu buttons versus things that can have multiple instances (Brain instances, Digital Output instnaces, Analogue Input instances, ect...) can be edited by the left top panel and added (new) by the top buttons.
Also if you are a graphics designer and want to help with the icons, let me know. I am no graphics designer!![]()
LinkBack URL
About LinkBacks
It is the beginning to a new configuration utility for the Fusion Brain. It will be fully compatible with Uber MDX Edition, which will be released within the month I hope. It is almost fully backwards compatible with Uber XNA.
