Results 1 to 3 of 3
Thread: configure the new mdx 3.0.0.0
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    when I open the mdx configuration how and where do I add my variables for the steering wheel controls. Like the voltage is between 3.39 - 3.97 for the mode button. vol up button is 1.0- 1.08 and so on. Do i add them in the at the fusion configuration xml document, under logic? It doesnt give me ''statements'' and then the ''if'' like in the old program. Just logic and then all ''logging'' and all ''variables'' Also when I open the mdx configuration I cant open configurations that I saved when I closed the program. When I click on the folder icon above thats says ''open a configuration file'' it does nothing. It like I start back over again every time I open the program, it tells me to add the brain and analog input
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by customaudioman View Post
    This is why I havent released MDX. The configurator is like 20% to 30% done. The main program is fully functional. Use Notepad or any XML document editor with the code provided in your other thread, and save it.
    You cannot open, because there is no open function implemented.
    And what you want to do is in the logic section of the configurator which I am only programming right now. (just updated the config thread).
    I posted the link just to help you out and get you a more stable, easier program that worked while the configurator was being programmed. Once it is released, both will be functional and included in a single installer.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    I should add, if you do actually encounter an error with the configurator, please post in the configurator thread: http://www.mp3car.com/vbulletin/soft...a-testing.html
    That way we can consolidate everything.
    So far there have been no errors, so it is looking good so far.
  1. Uber MDX Configurator Beta Testing...
    By 2k1Toaster in forum FB Software
    Last Post: 06-09-2008, 12:49 AM
  2. Configure StreetDeck to use Multiple GPS devices
    By CraziFuzzy in forum Wiki Discussion Threads
    Last Post: 10-21-2007, 10:56 AM
  3. Configure Dlink Radio
    By vicky_obee in forum Road Runner
    Last Post: 10-03-2007, 06:23 PM
  4. Replies: 3
    Last Post: 04-16-2006, 03:29 PM
  5. Replies: 0
    Last Post: 04-05-2005, 10:19 PM
