Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Integrate fusion brain commands into road runner buttons
  1. #11
    Aug 2006
    Central PA
    Can I use my existing skin with this? I just want to rename one of my rr buttons and have it execute the code that opens my garage door. An example or something would be nice. I'll look through your thread when I get off work.
  2. #12
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    yes you can use whatever skin you would like.. you would just need to modify commands on the skin. So you install RRFusion. And lets say open is port 0 on your FB and close is port 1, simply assign two buttons commands. First button is DIGITALOUT0TOGGLE and second button is DIGITALOUT1TOGGLE. Real easy
    Live mp3Car Facebook Chat
  3. #13
    Aug 2006
    Central PA
    Wow that is really simple. Thanks for putting that together .
  4. #14
    Woodbridge, VA
    Blog Entries
    41
    it was needed.. i will be expanding in the future as well. I'll implement timed events on the digital output commands soon. So you could put DIGITALOUT0ON;10 as a command. Using that command, the output would toggle ON for 10 seconds then turn itself off. a little logic never hurt nobody
  5. #15
    Jan 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    would it have to be two diffrent buttons in rr? how would u use two relays then? wouldnt it be just one button and one relay and the same command, "garage" for instance would do both open and close the gargage because the relay would only have to work for a second or so?? just like the restart button on carpc's. sorry i probably worded that horribly. i dont know how else to say it? hope u understand what i mean
  6. #16
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by djurchicprelude View Post
    you have two options with rrfusion:
    1. use the DIGITALOUT0TOGGLE command which is a toggle switch. Press the button once to turn the relay on , press the same button to turn it off
    2. use DIGITALOUT0SWITCH;5, which turns the relay on for 5 seconds then automatically turns it off. Of course, the 5 is just a random number and any number of seconds can be used.
  1. Road Runner Installation Program
    By bry21317 in forum Road Runner
    Last Post: 01-29-2008, 09:22 PM
  2. Road Runner Shell Issue
    By B|ade in forum Road Runner
    Last Post: 05-24-2007, 05:00 AM
  3. Multiple screens with Road Runner
    By Billious in forum Road Runner
    Last Post: 04-04-2007, 01:59 PM
  4. road runner freezing on startup :(
    By skiman in forum Road Runner
    Last Post: 03-13-2007, 09:37 AM
  5. Road Runner Resolution setting
    By JohnWPB in forum Road Runner
    Last Post: 03-01-2007, 10:02 AM
