ok, so i was working on steering wheel controls working
got all my Volt #'s from the car had it all setup like i thought but nothing actually happens
now the label displays the correct volts
but doesnt display as a decimal, it shows like 4897
Code:
<?xml version="1.0" encoding="utf-8" ?>
<FusionControlCentreConfiguration version="1.0.0.0" author="Kevin Holy" date_created="Tuesday, March 25, 2008 at 10:19:44 PM" last_modified="Tuesday, March 25, 2008 at 11:26:01 PM">
<require>
<!-- Begin Function Instances -->
<font name="LED50" originalSize="50" font_config="Content\config\fonts\FusionFontLED.xml"></font>
<!-- End Function Instances -->
</require>
<graphics>
<!-- Begin Global Graphic Settings -->
<main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True"></main_display>
<text_label id="Volt Monitor" text="00" auto_monitor="analogue input" auto_monitorTarget="Steering_Wheel_Control">
<font font_id="LED50" font_size="35"></font>
<display location="165,165" page="0"></display>
<config decimals="3" max_size="70,40"></config>
</text_label>
<!-- End Global Graphic Settings -->
</graphics>
<io>
<!-- Begin Fusion Brain Instances -->
<brain id="Holy's Brain">USB\VID_04D8&PID_000C\5&13735D69&0&2</brain>
<!-- End Fusion Brain Instances -->
<!-- Begin Timer Setup -->
<timer id="input" interval="75"></timer>
<timer id="output" interval="100"></timer>
<timer id="gui" interval="50"></timer>
<timer id="logic" interval="50"></timer>
<!-- End Timer Setup -->
<!-- Begin Digital Output Instances -->
<!-- End Digital Output Instances -->
<!-- Begin Analogue Input Instances -->
<iochannel id="Steering_Wheel_Control" port="0" brain="Holy's Brain" type="analogue_input">
<options history="0" auto_average="false"></options>
</iochannel>
<!-- End Analogue Input Instances -->
</io>
<logic>
<!-- Begin Logging Setup -->
<all_logging>
</all_logging>
<!-- End Logging Setup -->
<!-- Begin Variable Declarations -->
<all_variables>
</all_variables>
<!-- End Variable Declarations -->
<!-- Begin Logic Declarations -->
<all_statements>
<if fire_on="logic">
<boolean_operation type="and">
<parameter1>
<boolean_operation type="greater than or equal to">
<parameter1>
<analogue id="Steering_Wheel_Control" time="0"></analogue>
</parameter1>
<parameter2>
<number>1.6</number>
</parameter2>
</boolean_operation>
</parameter1>
<parameter2>
<boolean_operation type="less than or equal to">
<parameter1>
</parameter1>
<parameter2>
<number>1.8</number>
</parameter2>
</parameter2>
<then>
<do function="send key" functionTargetID="winamp" vote_opinion="Up Arrow" vote_priority="medium"></do>
</then>
</if>
<parameter1>
<parameter1>
</parameter1>
<parameter2>
<number>0.5</number>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
<number>0.7</number>
</parameter2>
</parameter2>
<then>
<do function="send key" functionTargetID="winamp" vote_opinion="Down Arrow" vote_priority="medium"></do>
</then>
</if>
<parameter1>
<parameter1>
</parameter1>
<parameter2>
<number>2.55</number>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
<number>2.8</number>
</parameter2>
</parameter2>
<then>
<do function="send key" functionTargetID="winamp" vote_opinion="Z" vote_priority="medium"></do>
</then>
</if>
<parameter1>
<parameter1>
</parameter1>
<parameter2>
<number>3.5</number>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
<number>3.75</number>
</parameter2>
</parameter2>
<then>
<do function="send key" functionTargetID="winamp" vote_opinion="B" vote_priority="medium"></do>
</then>
</if>
<parameter1>
<parameter1>
</parameter1>
<parameter2>
<number>4.2</number>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
<number>4.9</number>
</parameter2>
</parameter2>
<then>
<do function="send key" functionTargetID="winamp" vote_opinion="C" vote_priority="medium"></do>
</then>
</if>
</all_statements>
<!-- End Logic Declarations -->
</logic>
</FusionControlCentreConfiguration>
if someone could take a look at let me know why nothing happens
thanks!
