Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
Thread: Sample VB application to control a Fusion Brain
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    what time were the actual files updated.. i downloaded your source this morning and began working on converting it to an rr plugin. this was at about 11am eastern
    Live mp3Car Facebook Chat
  2. #12
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    Update was ~5 minutes before I posted the last message. Just check the version on the Form - I use the date as the version. If it's today's date, you have today's code.
    2k1toaster and I have been discussing the send/receive stuff in the Disconnect sub. It shouldn't be necessary to Receive data there, but it's the only way I can get it to disconnect and reconnect nicely. Can you try remarking out the recieve if/then in the disconnect Sub to see if it will allow you to reconnect after you disconnect?
    -Lance
  3. #13
    Woodbridge, VA
    Blog Entries
    32
    will do once i get the new source downloaded.. i gotta say thank you VERY much for releasing this open source as it has allowed a newb like me to understand how to communicate with the brain. If/when i release an rr plugin i will DEFINITELY be sure to credit you.
  4. #14
    Woodbridge, VA
    Blog Entries
    32
    ok.. when i comment then if/then statement the FB will not reconnect. the only way i can re-establish a connection is if i close the program AND disconnect/reconnect usb. Now with the if/then uncommented it connects/disconnects/reconnects as it should.
  5. #15
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Sonicxtacy02 View Post
    If you know how to make a COM object I would be forever greatful!
    It just isnt working for me.
    And I have not updated the source in a long time. I will package it all together and post it for you. That USB communication however has not changed at all.
    1.9in x 2.9in -- 47mm x 73mm
  6. #16
    Woodbridge, VA
    Blog Entries
    32
    i know how to do it in vb6.. does that help? lol Quite frankily i dont even know what program you use to open a C# source package... but i'm pretty good at learning on the fly!
    In all honesty though i'm hoping the rr plugin i'm making will satisfy all users using rr and wanting to implement the FB into it. As i stated earlier (or maybe in another thread), it will have the ability to control all digital outputs, as well as display raw data in the form of labels and variables and also parse the data for items like the temp and photo sensors. I think a com object would definitely add to the popularity of the FB.. but least this plugin will get the RR vultures off your back for awhile lol
  7. #17
    Mar 2006
  8. #18
    Apr 2008
    Baghdad, Iraq/Fort Bragg, NC/Saginaw, MI
    Input
    Just a bit of input from a "programmer" =D
    AnalogIn(i) = (CInt(InputArray(i * 2 + 12)) * 4) + CInt(InputArray(i * 2 + 13) / 64) 'Uses both bytes 0-1023 (10 bits)
    that line is beautifull.
    seriously, my solution was 8 lines long, converted to binary, used all 16 bits, and converted back to a long =D
    But on a serious note; do you have a layout of the output (64b) from the Fusin Brain? IE, what each byte/bit means? I see that you have bytes 12-36 in use... what are the other 40 or so bytes used for? Also, where does it hide the digital inputs?
    My FBs have been backordered for 2 weeks, so my real-world dev time has been pushed back a bit =D I'm going to be running 2 FB's in my prelude, with a custom program.
    I'm also working in VB2k8, so this app really saved me alot of dev time =)
    Mike
  9. #19
    Mar 2006
    and i is from 0 to 10 correct? That is a nice line of code indeed. May just use that in the main program. I was too busy to figure it out, so I used strings
  10. #20
    Aug 2003
    Iowa
    "i" is 0 to 11 for the 12 inputs.
    As for other bytes, there really is nothing else of value in the byte array. There is one byte that has the 4 digital inputs, but since the digital inputs are going away in the next version, I decided not to use them at all. Just act like they aren't there.
    There is a word document around somewhere that lists the specs of the byte arrays. I don't know what the URL is to it, maybe 2K1 has it posted somewhere.
    -Lance
  1. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  2. power fusion brain from car battery
    By customaudioman in forum Fusion Brain
    Last Post: 03-14-2008, 07:41 PM
  3. Skinning a custom VB application
    By RJP350Z in forum Software & Software Development
    Last Post: 01-11-2005, 09:36 AM
  4. VB front end for SB Audigy control?
    By wysocki in forum Software & Software Development
    Last Post: 12-14-2004, 08:36 PM
  5. VB Control for Character LCD's
    By Jamez_Warner in forum LCD/Display
    Last Post: 05-17-2004, 04:55 AM
