Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
Thread: Sample VB application to control a Fusion Brain
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by mx270a View Post
    "i" is 0 to 11 for the 12 inputs.
    As for other bytes, there really is nothing else of value in the byte array. There is one byte that has the 4 digital inputs, but since the digital inputs are going away in the next version, I decided not to use them at all. Just act like they aren't there.
    There is a word document around somewhere that lists the specs of the byte arrays. I don't know what the URL is to it, maybe 2K1 has it posted somewhere.
    -Lance
    There are only 10 inputs, 12 outputs. So 0 to < 10
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by 2k1Toaster View Post
    see the code is futureproofed too!
    Live mp3Car Facebook Chat
  3. #23
    Mar 2006
    Indeed. Assuming the bytes are back to back, which we hope to keep it like that.
  4. #24
    Apr 2008
    Baghdad, Iraq/Fort Bragg, NC/Saginaw, MI
    2k1, would you happen to have a proto of the current, and new output? I'm assuming the 13 analog outs will simply stack in with the current ones, so that update will be simple; but as for the current digital in's... its at byte #33, starting with 1, or byte #32, starting with 0, correct? also, what is the format for the byte?
    IE,
    240(11110000, little endian) = all 4 digital inputs on, 0(00000000) = all 4 off?
    15(00001111, little endian) = all 4 digital inputs on, 0(00000000) = all 4 off?
    also, which bit corresponds to which input? I would assume that the 128 bit corresponds with the first digital input..
    I would usually just do the whole trial and failure method, but I've got a couple of weeks before I get my testing brains in.
    V/r,
    SGT Michael J Cunningham
  5. #25
    Mar 2006
  6. #26
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    Yeah, 10 inputs, my bad. Must have been thinking of the outputs.
    -Lance
  7. #27
    Apr 2008
    This is PERFECT! I'm sorry, I missed this tutorial... I scanned through the list a couple of times, but leave it to me, to miss the very first tutorial =/
    Also, sorry for Hi-jacking mx270a's thread,,, seemed like the most appropriate place to ask something like this.
    And last but not least; For your information; I am working on a custom interface for my prelude, that controls a thing or 2... at the moment, it has 2x servo-controlled webcams, 6x servos to control the amps, and 2 servos for the A/C controls, which can all be controlled from my PSP. But, being that I'm currently in IRAQ, I figured it would be a good time to incorporate a bit of usefullness into the system, by adding a couple of Fusion Brains =)
    Thanks again!
  8. #28
    Mar 2005
    Quote Originally Posted by conjur View Post
    i think we just added it
  9. #29
    May 2008
    Cannot get this to work
    Hi,
    I have downloaded this example and i cannot get it to work. It always says no drivers installed or cannot locate dll file.
    The only drivers i can install are the PIC drivers. I assume I need the ones that say Da Fusion, but these fail with the following error:-
    The required section was not found in the .INF.
    Please help, all I want to do is have drivers that work and a simple vb example.
    Many thanks
  10. #30
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by WayneA View Post
    Hi,
    Many thanks
    i've seen that error too on one of computers.. i used an older version of the hardware driver and it worked for me. then i just updated it manually
  1. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  2. power fusion brain from car battery
    By customaudioman in forum Fusion Brain
    Last Post: 03-14-2008, 07:41 PM
  3. Skinning a custom VB application
    By RJP350Z in forum Software & Software Development
    Last Post: 01-11-2005, 09:36 AM
  4. VB front end for SB Audigy control?
    By wysocki in forum Software & Software Development
    Last Post: 12-14-2004, 08:36 PM
  5. VB Control for Character LCD's
    By Jamez_Warner in forum LCD/Display
    Last Post: 05-17-2004, 04:55 AM
