Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: Sample VB application to control a Fusion Brain
  1. #31
    May 2008
    I finally found the coinstaller drivers...they installed and then said "they may not have worked"...
    I reset the brain and now im getting somewhere. I ca get the lights to light up on the outputs, but my relay does not fire....any ideas?
  2. #32
    May 2008
    im all working now. I dont think my wires were seated correctly.
  3. #33
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    Check this thread to see if it resolves your problem:
    http://www.mp3car.com/vbulletin/fusi...ion-2-fix.html
    Edit: nevermind. I didn't see the last two posts.
  4. #34
    Aug 2003
    Iowa
    Several people have expressed interest in reading the digital inputs. I added that bit of code to this sample application so others can see how to do that. The screenshot and links in the first post of this thread point to the current version.
    Caveats:
    -Greenman and 2k1toaster have said the digital inputs are going away in the next version of the fusion brain. The analog inputs can read a digital signal.
    -A simple SPST switch isn't good enough on these inputs. They need to be pulled to either ground or +5 volts, not just disconnected.
    -When the digital inputs aren't pulled to ground and you turn on digital output 11, the inputs will all go high. When you turn off output 11, they go back to low. This shouldn't be an issue when something is plugged into the digital inputs.
  5. #35
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by mx270a View Post
    This is probably just an issue on your particular board... there's something bridging the traces.
  6. #36
    Aug 2003
    Iowa
    Quote Originally Posted by greenman100 View Post
    Yeah, could be. It's sitting on an anti-static bag. I tested this with a second FB while holding it in the air, and got similar results. However, I haven't actually tested this with anything more than using my finger to send some voltage from the +5 pin to the signal pin. (I'm sure you guys love to hear that.) It probably would work fine with a real input, I just haven't taken the time to wire up a switch to some pins.
  7. #37
    Mar 2006
    Would be awesome if somebody could port to C# really interested in using the FB quite extensively in my system at the moment.
  8. #38
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by monzablue16v View Post
    All of our software is written in C#. It was ported to VB...
    1.9in x 2.9in -- 47mm x 73mm
  9. #39
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Caveats:
    Mind if i had your code from digitial inputs into RRFusion? I just havent had the time to see how they work myself
    Live mp3Car Facebook Chat
  10. #40
    Aug 2003
    Iowa
    Quote Originally Posted by Sonicxtacy02 View Post
    Go ahead. I might recommend somebody test this new chunk of code thoroughly before getting too aggressive at coding anything. I think I got the right bits, and it acts fine to me, but I haven't done any serious testing with it.
  1. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  2. power fusion brain from car battery
    By customaudioman in forum Fusion Brain
    Last Post: 03-14-2008, 07:41 PM
  3. Skinning a custom VB application
    By RJP350Z in forum Software & Software Development
    Last Post: 01-11-2005, 09:36 AM
  4. VB front end for SB Audigy control?
    By wysocki in forum Software & Software Development
    Last Post: 12-14-2004, 08:36 PM
  5. VB Control for Character LCD's
    By Jamez_Warner in forum LCD/Display
    Last Post: 05-17-2004, 04:55 AM
