Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: Fusion Brain Latest Software MDX - Download Link
  1. #31
    Oct 2006
    Las Vegas
    COX, LV,NV, works great for me. ~1.85MB/Sec downloaded again today.
    Microsoft Windows [Version 6.0.6000]
    Copyright (c) 2006 Microsoft Corporation. All rights reserved.
    C:\Users\h3rk>tracert -h 100 www.fusioncontrolcentre.com
    Tracing route to fusioncontrolcentre.com [72.167.173.3]
    over a maximum of 100 hops:
    1 1 ms <1 ms <1 ms 192.168.2.1
    2 7 ms 9 ms 11 ms ip68-229-60-1.lv.lv.cox.net [68.229.60.1]
    3 9 ms 13 ms 8 ms 24-234-1-201.ptp.lvcm.net [24.234.1.201]
    4 10 ms 9 ms 9 ms 24-234-6-25.ptp.lvcm.net [24.234.6.25]
    5 15 ms 13 ms 16 ms langbbrj01-ae3.0.r2.la.cox.net [68.1.0.94]
    6 20 ms 70 ms 23 ms xe-1-1-0.mpr3.phx2.us.above.net [64.125.28.69]
    7 * * * Request timed out.
    8 25 ms 25 ms 21 ms ip-208-109-112-137.ip.secureserver.net [208.109.112.137]
    9 24 ms 23 ms 26 ms ip-208-109-112-161.ip.secureserver.net [208.109.112.161]
    10 25 ms 26 ms 21 ms ip-208-109-112-145.ip.secureserver.net [208.109.112.145]
    11 25 ms 25 ms 22 ms ip-208-109-112-173.ip.secureserver.net [208.109.112.173]
    12 27 ms 36 ms 24 ms ip-72-167-173-3.ip.secureserver.net [72.167.173.3]
    13 30 ms 27 ms 33 ms ip-72-167-173-3.ip.secureserver.net [72.167.173.3]
    Trace complete.
    C:\Users\h3rk>
    Didn't know if you only wanted the ones that don't work or both, so I did one anyway.
  2. #32
    Newbie ATT41's Avatar
    Dec 2008
    Australia - Brisbane
    Is this the most recent software? Has this been updated for 5.0?
    [H]
    ____╔══════╗____
    OOO/ATT41\OOO
  3. #33
    Mar 2006
    Colorado, but Canadian!
    The link stays the same, the software keeps updating. You will probably see an update download after you use the installer, I dont think the big package is the newest right now.
    1.9in x 2.9in -- 47mm x 73mm
  4. #34
    Aug 2006
    Central PA
    Any plans on x64 support? I'm going to need to set up another machine just to run the mdx software until x64 is supported (Win 7 that is).
  5. #35
    Aug 2006
    Central PA
    I installed Windows XP mode in Windows 7 x64. The software installs correctly (I think). The drivers load fine and all is well in the world. I can go into the configurator and it sees the brain and I'm able to add the unique number.
    The road block is that the Fusion Control Centre software won't start. I get a "Fusion Control Centre UberMDX has encountered a problem and needs to close. We are sorry for the inconvenience."
    The event viewer give me .net runtime 2.0 error reporting event id 1000. It looks like it's almost working.
    Edit:
    I got it working. I installed it on my xp laptop and got the same problem. I fixed it by uninstalling dot net 2, 3, 3.5 and then I installed just 2, 3, and 3.5 without the service packs. Then I installed dot net 1. I rebooted and then ran the installer again. It looks like it installed MDX files this time around that it didn't the first time. It worked afterwards. This worked inside my Winxows XP mode running inside of Windows 7 x64 as well .
  6. #36
    Mar 2006
    Interesting... It should not work with x64 systems (yet). The new software that hasn't been released yet does work on x64 7/Vista/XP but it is still being programmed.
  7. #37
    May 2010
    Quote Originally Posted by 2k1Toaster View Post
    Any idea on when the x64 version, or beta will be released?
  1. Fusion Brain Reloaded
    By greenman100 in forum Fusion Brain
    Last Post: 12-17-2008, 10:00 PM
  2. Does Fusion Brain allow Hibernation
    By rgarjr in forum Fusion Brain
    Last Post: 04-10-2008, 12:30 AM
  3. Why no obvious download link?!
    By Engram in forum Road Runner
    Last Post: 03-14-2005, 12:57 PM
  4. where can i download gps software
    By SRI Allan in forum GPS
    Last Post: 05-01-2004, 01:19 PM
