Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Fusion Brain Latest Software MDX - Download Link
    Mar 2006
    Colorado, but Canadian!
    EXE (97,215Kb): http://www.fusioncontrolcentre.com/M...0Installer.exe
    RAR (93,574Kb): http://www.fusioncontrolcentre.com/M...0Installer.rar
    ZIP (94,925Kb): http://www.fusioncontrolcentre.com/M...0Installer.zip
    This is the newest version of the software. It is very different and much more powerful than the previous version. It has been out for a while, but it is now at a point where it can be for everyone.
    Needed to Run:
    MDX:
    Vista or XP
    .NET 3.5
    Direct X 9.0c
    Configurator:
    Vista or XP
    .NET 2.0
    It has:
    a) .NET 2.0
    b) DirectX 9.0c
    c) Main MDX Program
    d) MDX Configurator
    e) MDX Updater
    It will unpackage and install .NET 2.0 and DX 9.0c hopefully by itself with no need for user input there.
    Then if you leave the finish page with the default checks, it will start the updater and check for new versions, as well as start the configurator with the sample skin loaded.
    I added a parameter to the configurator that anyone can use. It is: -open:"blah.xml" where blah.xml is the config file to open. It can be a relative path or an absolute path.
    The installer is close to 300Mb. That is the price you pay for idiot-proofing.
    1.9in x 2.9in -- 47mm x 73mm
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    is it now com enabled?
    Live mp3Car Facebook Chat
    Philly
    sorry to be bother.....what's the difference?
    Mar 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    Yes and no. Still having troubles. I have the COM object working in a test project, communicating to RoadRunner and displaying on a label.
    But taking that code and just putting it into my large code (MDX), it is a no go... So I am trying to debug that, but things are slow going. So the code is there, but nothing happens. It will though later.
    Quote Originally Posted by dasaint80 View Post
    MDX is logic based. Meaning outputs and inputs are not tied to an image. Everything is very generic and broken apart making it virtually endless in the possibilties. You can create logic to do everything from animation to evaluating a numeric function.
    Also everything is based on a voting system. You push a button on the skin, it doesnt turn the output on or off. It will tell the output it WANTS to turn it on or off. The button then will tally all votes it got during that cycle from user input, logic evaluation, and server requests, and decide whether or not it wants to turn on or off. If a vote has a higher priority (low/medium/high) then it will win, and disregard any number of lower priority votes. Good for overrides.
    Another major change is now it uses Managed Direct X (Hence the name MDX). This means it no longer uses GDI+ which is slow but easy to code in as the last versions were.
    There are lots of other changes too such as seperating everything onto 4 timers, so you can read inputs, sends outputs, update the GUI, and evaluate the logic all at different times with differtent intervals between them.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    The installer is close to 100Mb. That is the price you pay for idiot-proofing.
    its sitting at 274mb at the moment... is that correct?
    Mar 2006
    Yes. I havent updated the page but I have updated the installer.
    It now includes:
    Windows Installer 3.1
    Microsoft .NET 2.0 Framework
    Microsoft .NET 3.0 Framework
    Microsoft .NET 3.5 Framework
    DirectX 9.0c Full Installer
    Fusion Control Centre Uber MDX
    MDX Configurator
    MDX Updater
    The jump in size is from the addition of the 2 extra frameworks and the 3.1 installer. .NET 3.5 requires 3.1 installer, and XP comes with 3.0 stock.
    May 2007
    Wichita, KS
    any mirrors for this? my download from fusioncontrolcentre.com keeps failing after about 5 minutes of 10kb/sec...
    May 2007
    Wichita, KS
    bump... still cant download this....
    Mar 2006
    The problem is on your end. Lower your security settings or something.
    I just downloaded all 3 of the installer packages at over 1Mbps.
    Here is a direct link to the exe: http://www.fusioncontrolcentre.com/M...0Installer.exe
    May 2007
    Wichita, KS
    negative i just finished downloading 2 gig demo from fileplanet at 500+ kb/sec.
    maybe theres a bad hop between my connection and the webserver.
    either way, a mirror would fix it.
    or, does this installer come with the fusion brain? mine should arrive monday. if it doesnt, this is going to be very frustrating.
  1. Fusion Brain Reloaded
    By greenman100 in forum Fusion Brain
    Last Post: 12-17-2008, 10:00 PM
  2. Does Fusion Brain allow Hibernation
    By rgarjr in forum Fusion Brain
    Last Post: 04-10-2008, 12:30 AM
  3. Why no obvious download link?!
    By Engram in forum Road Runner
    Last Post: 03-14-2005, 12:57 PM
  4. where can i download gps software
    By SRI Allan in forum GPS
    Last Post: 05-01-2004, 01:19 PM
