Results 21 to 30 of 33
Thread: MDX Now does Speech Recognition!
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Could very well be a bug. I will check into it later tonight.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Dec 2007
    Is there a way to delete the commands I do not want yet? I want to delete the ones that do no start with the system name.
  3. #23
    Mar 2006
    Quote Originally Posted by RonS View Post
    It should be in there and has been since the big update.
    As long as there is a system name specified, that is the only thing that will be used to create the strings.
    If you specify no system name, it adds a default name of "" (nothing).
    If it is still not working for you, take a screenshot of the speech debug form so I can see what commands you are talking about.
  4. #24
    Dec 2007
    Sorry I have been busy and have not taken a screen shot yet. I was just wondering if this could be the problem.
    <speech enabled="true" global_politeness="true">
    <!-- Begin System Speech Instances -->
    <system_name></system_name>
    <system_name>Computer</system_name>
    <!-- End System Speech Instances -->
    There are 2 system_name definitions. I am at work so cannot do much. But if I take out the blank one the program takes out the defined one.
  5. #25
    Mar 2006
    You should be able to take out the blank one no problem, but that blank one is definately the problem.
  6. #26
    Dec 2007
    Ok... I removed it. Then opened it again in the configurator. This is what it says now.
    It took out the name. Such fun. I am still at work. So will try it at home and see what happens.
  7. #27
    Mar 2006
    Just remove it in the xml file, and try in mdx
  8. #28
    Dec 2007
    Ok I have it figured out. You have to first set up the speech parms that you want. then save it. Then go into the xml and add the system name. If you go back into speech setup. You will have to edit the xml with the name. Also turn off politeness until you have it working the way you want or you will want to kill it before you are done. But it is working. And will now not do any command unless you say the system name first. Oh and I am using it in XP with no problem. I think at one time someone said something about it only being tested in Vista.
  9. #29
    Dec 2007
    Ok I know I am a pest.... But .... When you get time can you look at the Custom Query's. It is only saving the first one.
  10. #30
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    If nothing else, the politeness is a good way to test to see if the speech is working (kinda like pinging 127.0.0.1)
    This is awesome!
  1. shotgun & array microphones for speech recognition
    By kykeon in forum Input Devices
    Last Post: 08-09-2008, 03:30 PM
  2. Speech recognition
    By ZbyszekPluta in forum General MP3Car Discussion
    Last Post: 01-11-2007, 05:24 PM
  3. Speech Recognition
    By eclipseGT in forum Show off your project
    Last Post: 10-11-2005, 05:15 PM
  4. Bruno Speech Recognition BETA v1.2
    By FunkDaMonkMan in forum Bruno Speech Recognition
    Last Post: 05-03-2005, 02:03 PM
  5. speech recognition
    By TheChiman in forum MacCar
    Last Post: 03-24-2005, 02:38 PM
