Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 62
Thread: Creating fonts in Configurator
  1. #11
    Jun 2008
    Georgia, USA
    Put everything on a single line and don't press <enter> at the end.
    Thanks,
    Dan
  2. #12
    Mar 2006
    Colorado, but Canadian!
    You dont need everything on a single line.
    But it does need a completely vertical line with nothing in it for that font height. Set the distance between characters to a value not just "auto" and it will evenly space giving good distance between. Then when it asks for font height, also make sure you set the height to how high 1 character is. If you used 25pt font, set it to 25.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Mar 2006
    Just for example, the current font file I am using for the new Wizard is below. Notice the spacing between letters. There is no overhang, so there is a 1x25 pixel dead zone between each character where the config will snip from. I am still trying to think up a good character recognition system so you dont even have to type in the characters' values, but that is way in the future.
    Actual Image (if on a laptop, put the screen at a huge angle and the contrast will show better):
    Image With a black background just so you can see it:
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    might make a good FAQ...I'll give this a try tonight. Thanks for the additional info.
    Nick - if you need help developing some of this, I'll be happy to write it up as I go through the learning process. I've found in the past that it's sometimes the easiest and most thorough way.
    It's what I did when I started at Centrafuse. Started learning and writing FAQs at the same time.
    Just let me know.
    Jan Bennett
  5. #15
    Mar 2005
    Quote Originally Posted by RedGTiVR6 View Post
    Just let me know.
    We'd appreciate all the documentation we can get...
  6. #16
    Jun 2008
    Georgia, USA
    Well, I just tried it again and can't remember exactly what I did to get the characters recognized corectly.
    I made a PNG with 64 characters and the analyze function found 114.
    Is there a rule-of-thumb size for the font, canvas and dpi? I started with 20pt Arial on a 1024x768 canvas at 300dpi. When I opened the image file, I entered 20 in the popup font height dialog. Then the character height defaulted to 768 so I tried to change it to 20. This produced a "character height is not a multiple of font size" (or something to that effect) error.
    Thanks,
    Dan
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by 2k1Toaster View Post
    Aighty - looks like this is going to be a lesson in Photo shop for me as well.
    So, not being 100% sure I understand what you've said above, I did some poking around in Photo Shop.
    I have toggeled the Character and Paragraph pallets on.
    Under the Character tab, I've selected the following:
    Arial - Regular
    Font Size: 24 pt
    Leading: 10 pt
    Kerning between characters: 5
    Anti-aliasing Method: none
    When I go to Analyze the image, the text box that's there enters 300. If I change it and the Character Height to 24, then I get the same error mentioned above:
    If I just leave it at 300, then it will go through the process and tell me no characters found.
    Now, I did hit enter between each line, but I made the canvas large enough to hold one full go at the alphabet in caps, then lower case, etc.
    Attached the new one. Any ideas?
    Jan Bennett
  8. #18
    Mar 2006
    All that empty space down there is a no-no.
    Make the image exactly the size. If it is 24pt font, then with 4 rows of characters the canvas should be 96px high. Width anything. Spacing looks good though.
    In the image below, going from top to bottom with the highlighted items, is A, B, and C
    So click A, and the text properties popup. Then change B to something that spreads them out. I find it makes it nice with something close to the same size as the font size. Then you can see that I have 25pt font, and 3 rows of it. So the font is 75px high as in C.
    So get rid of that empty space. Also a 1024x768 image will eat your video card alive for a font. Every character accesses that file multiple times. Smaller is better.
  9. #19
    Jun 2008
    Georgia, USA
    Hmmm...ain't working for me. I have three lines of 20pt text so I made the canvas 60px high...oh, just realized what my problem is--my font is in points and my canvas is in pixels.
    So what you are doing is creating a map for each character in the image file and when it comes time to display a character, you are cropping X,Y pixels at position A,B pixels. Smart!
    Thanks,
    Dan
  10. #20
    _
    Mar 2004
    Little Elm, Texas
    ok - I'm completely lost here.
    I've created a file that's just ONE line, and I've specified that it would be the EXACT same height....24 points....as the font....24 points.
    I've not even included the whole alphabet, just a sample of it.
    When adding a fusion font, it's finding the height of the text right...but it's not finding ANY text.
    Anyone?
    .psd file included in .zip...
    Attached Files Attached Files
    Jan Bennett
  1. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 10:33 AM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
