Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 62
Thread: Creating fonts in Configurator
  1. #51
    Mar 2006
    Colorado, but Canadian!
    no problem. I never used the program so I didnt even know if it was there or not, but it better be for an image editing program!
    1.9in x 2.9in -- 47mm x 73mm
  2. #52
    Jun 2008
    Georgia, USA
    I will put together a short, step-by-step tutorial sometime today.
    Thanks again for the help.
    Thanks,
    Dan
  3. #53
    Jun 2008
    Georgia, USA
    Whew...I have a 15 page Word document with step-by-step instructions for defining a new Fusion Font.
    Would you like me to email it to you for proofing or should I just post it in the documentation forum?
    Dan
    Thanks,
    Dan
  4. #54
    _
    Mar 2004
    Little Elm, Texas
    Dan - if you can write up a tutorial, I'd appreciate it!
    Jan Bennett
  5. #55
    Jun 2008
    Georgia, USA
    One problem I am running into is saving the font configuration file after defining all of the characters.
    Every time I try to save the file I get en error dialog telling me the file is in use by another process. Using a utility to show open file handles, nothing has the file open.
    How do I get around this???
    Thanks,
    Dan
  6. #56
    Jun 2008
    Georgia, USA
    Quote Originally Posted by Dan2008 View Post
    Just to be sure nothing had the file open, I rebooted and started the Configurator. I opened the font image file, analyzed it and tried to save it. This still produced the same error and the Configurator was the only program executed after the reboot.
    Something about the way the file is opened is not allowing the file to be saved.
    Looking at the detailed output from the error, it is trying to save xxx.png. Shouldn't this be xxx.xml instead?
    Thanks,
    Dan
  7. #57
    Jun 2008
    Georgia, USA
    Okay, found the problem there. I initially placed the image file in the fonts directory. When saving the file, the program attempts to create a new image file with the same name in the fonts directory.
    Moving the image file to another directory allow the font file to be saved.
    I looked at the source for AddFontForm.cs and it creates the filestream with FileMode.OpenOrCreate and FileAccess.ReadWrite so I don't know what the issue is. That should allow overwriting the existing file.
    Thanks,
    Dan
  8. #58
    Jun 2008
    Georgia, USA
    I'm going to go ahead and post the tutorial here. Check for errors as you go through it and let me know if anything needs to be changed or if it is unclear.
    If everything is okay then Nick might want to move it to the documentation forum.
    Attached Files Attached Files
    Thanks,
    Dan
  9. #59
    Mar 2005
    Thanks Dan!
    If you guys want to upload your fonts, we can include them in future releases of the Configurator
  10. #60
    _
    Mar 2004
    Little Elm, Texas
    It would be cool to have some of the most commonly used fonts already loaded when you download the program. Or perhaps a repository of user created fonts on the site?
    Downloading the .doc file and will go over it this afternoon. Thanks!
    Jan Bennett
  1. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 10:33 AM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
