Page 1 of 7 1234567 LastLast
Results 1 to 10 of 62
Thread: Creating fonts in Configurator
    Jun 2008
    Georgia, USA
    How does one go about creating a font using the configurator?
    I created a PNG file with the characters and when I tried to open it in the "Add or Edit Fusion Font" dialog, all that shows are XML files regardless of whether you click the "Open Font File" or "Open Image File" icon.
    Thanks,
    Dan
    Mar 2006
    Colorado, but Canadian!
    Yup, the only showing xml files when selecting an image, is a bug. Just fixed it right now. I am uploading a new file to the updater.
    Also there was a bug in the Updater (I switched my debug and non-debug modes, whoops) so the past few releases, it will never check the server for updates. It will only check a nonexistant file on your computer for updates, so it wont update.
    I will post a link to a new standalone updater to replace the current one later tonight.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2008
    Georgia, USA
    Thanks.
    I copied an existing XML file, renamed it and pointed it to my PNG file. When I bring it up in the font editor I can see the characters and can edit the locations to center them but if I run the analyze function, it cannot find any characters.
    I've been reading a rather long thread about the configurator beta test and I think I'm creating the PNG correctly (but not sure). Should the characters themselves be transparent?
    It could be that the graphics app I'm using doesn't create the alpha channel correctly or something.
    Thanks,
    Dan
    Jun 2008
    Georgia, USA
    Oh, one other thing I've ran into--I cannot seem to drag from the top left panel to the trashcan. Does this function work yet?
    Thanks,
    Dan
    Jun 2008
    Georgia, USA
    Okay...got it to analyze!!! It was me (no surprise there) not creating the alpha channel correctly.
    After analyzing the PNG and entering the value for each character, I get an error every time I try to save the file. It says the PNG is in use by another process.
    I copied the XML from the bottom left panel and pasted it into the XML file and it works just fine but the file save needs to be looked at. Its like the file has been opened read-only instead of read-write.
    If you can point me to the correct section of code I will look at it.
    Thanks,
    Dan
    Mar 2006
    Quote Originally Posted by Dan2008 View Post
    Make sure you dont have the image open in another program. Something like photoshop keeps exclusive rights sometimes. Is the configurator the only program open?
    Jun 2008
    Georgia, USA
    That was my first thought so I tried with one of the PNGs included in the download and got the same result.
    The configurator is the only thing running.
    Thanks,
    Dan
    _
    Mar 2004
    Little Elm, Texas
    I'm entirely new to this stuff and I'm not sure I even understand this part.
    So I'm guessing that you have to create a PNG file with each of the letters in the alphabet...so basically open PS up and create a new file with all of the letters typed out in the font you want to use. Then use the 'Add or Edit Fusion Font' page to basically see each of the letters and import it (of sorts) to the program?
    Jan Bennett
    Jun 2008
    Georgia, USA
    Quote Originally Posted by RedGTiVR6 View Post
    That's basically it. Make sure you leave space between each character so you can isolate it in the font designer.
    Also, make sure the PNG file indeed has the alpha channel--that was giving me a hard time until I figured out that I wasn't actually creating the alpha channel.
    Thanks,
    Dan
    _
    Mar 2004
    Little Elm, Texas
    Thanks.
    I'm not sure how to create the alpha channel. Off to Google!
    Hrmm....
    The .xml that's created:
    Code:
    <?xml version="1.0" encoding="utf-8" ?>
    <font fontImage="Arial_Alphabet-1.png">
      <char location_topleft="4,0" location_bottomright="164,184" value="???" offsets="0,0,0,0"></char>
      <char location_topleft="166,0" location_bottomright="291,184" value="???" offsets="0,0,0,0"></char>
      <char location_topleft="292,0" location_bottomright="311,184" value="???" offsets="0,0,0,0"></char>
      <char location_topleft="315,0" location_bottomright="381,184" value="???" offsets="0,0,0,0"></char>
      <char location_topleft="385,0" location_bottomright="477,184" value="???" offsets="0,0,0,0"></char>
    </font>
    Pretty obvious that I've done something wrong....but what?
    Jan Bennett
  1. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 10:33 AM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
