Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 61
Thread: **NEW Fusion Control Centre Configuration Wizard!**
  1. #51
    Oct 2006
    Las Vegas
    Quote Originally Posted by RedGTiVR6 View Post
    That's actually .0782...not .782...
    If I jumper the two outside pins for that analog input, I get .15~.16
    Normal?
    No, you should see 5V. The innermost is the onboard 5V supply, and the outer pin is the sensing point. So you should see the full 5V at that particular input. Is it that way for all of the analog inputs? If so, there's likely something wrong with the brain. Maybe check the voltage at the innermost pin with a meter. And with your sensor attached, maybe you can check the sensing pin with a meter too.
  2. #52
    Mar 2006
    Colorado, but Canadian!
    Normal?
    No that means something is fried. You should get 5v if you jumper them.
    Is this on all ports, or just the one?
    1.9in x 2.9in -- 47mm x 73mm
  3. #53
    _
    Mar 2004
    Little Elm, Texas
    Wait, I'm confused....the past two posts kinda contradict each other.
    Specifically, which two pins should I short?
    The inside and one of the outside pins? If so, which outside pin?
    The two outside pins?
    Jan Bennett
  4. #54
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by 2k1Toaster View Post
    A1 = 4.9
    A0 ~ 0.07
    A3 = 0.2737
    A5 = 0.391
    A4 = 0.87
    A7 = 1.3294
    A6 = 1.85
    A9 = 2.7321
    A8 = 4.49
    What's strange (and maybe it's normal?) when I short these they all show up under Analogue Input #01 under the Virtual Brain....is that normal?
    Jan Bennett
  5. #55
    Oct 2006
    Las Vegas
    Hardware Manual
    Figure 2. on page 3. Lower right box:
    Pin 1 to Pin 3 should make FCC see 5V. Pin 2 to Pin 3 should read 0V.
    Pin 1 to Pin 2 should be avoided.
  6. #56
    Oct 2006
    Las Vegas
    A1 = 4.9
    A0 ~ 0.07
    A3 = 0.2737
    A5 = 0.391
    A4 = 0.87
    A7 = 1.3294
    A6 = 1.85
    A9 = 2.7321
    A8 = 4.49
    That's odd, but it's likely the other ones are reading noise, due to the way the PIC reads the voltages in. What is important is what the particular input you are jumpering reads, when you jumper it. Is that what this list is? If so, it looks like only A1 is working properly. That's why I assume that this is a list of all inputs when A1 is jumpered.
    I kind of know what you are talking about, and I thought it was just me. It seems like you have to create an instance of each input in the skin to get the input to show up correctly, in the right place, on the Virtual Brain. That's been my experience before.
    So if you only have an instance of A1 in the skin, and you jumper A5, you will see garbage on the Virtual Brain. It may not be the case, but I thought it was worth sharing that experience of mine. I disregarded it before, as inputs that I'm not using don't matter...usually.
  7. #57
    Mar 2006
    A1 = 4.9
    A0 ~ 0.07
    A3 = 0.2737
    A5 = 0.391
    A4 = 0.87
    A7 = 1.3294
    A6 = 1.85
    A9 = 2.7321
    A8 = 4.49
    You mean each label reads something when you short right? So you get a stepped sort of tier down. If so that is normal. If not, then please post a screenshot.
    Quote Originally Posted by h3rk View Post
    Hardware Manual
    Pin 1 to 2 should not just be avoided, it should NEVER be done. That is shorting power to ground. It will destroy your Fusion Brain.
    That is not true. The labels on the virtual brain read in exactly what it tells the program. Even if you only have 1 analogue input, the byte stream it reads contains basic data for every input regardless. It passes that data directly to the Virtual Brain Form, no middle man. It is the exact same data source that the function parser uses, same source the logger uses, same source the gui uses. 1 big static list in RAM. So it will never display garbage, only what it uses. If you have auto-averaging turned on, it will show the value after having been averaged because that averaged value is again what is used everywhere else in the program.
  8. #58
    Oct 2006
    Las Vegas
    My sarcasm/humor did not come across well.
    That's good info to know. I don't know what I was seeing then...nevermind.
  9. #59
    _
    Mar 2004
    Little Elm, Texas
    Hardware Manual
    Good to see there's a manual now! There wasn't when I looked for one just a few weeks ago.
    I can short each and every one individually, yet it always shows up under A1 on the Virtual Brain. I never get any of the others to show up. Shorting A8 on the brain, will get A1 on the virtual brain to show up with the reading.
    Good thing I didn't do that...
    So then....is it safe to assume that this FB is toasted? What do I need to do to get a replacement?
    Jan Bennett
  10. #60
    Mar 2006
    Manual has been on mp3car in its own post since March 08: http://www.mp3car.com/vbulletin/docu...er-manual.html
    And has been in various topic relies since end of summer 2007.
    If that is true, then something is wrong hardware wise.
    Send us it back, and we will send you a new one. Send us an email at FusionControlCentre at gmail dot com and we will replace it. `s
  1. RRFusion- My Fusion Brain plugin for RR
    By Sonicxtacy02 in forum RR Released Plugins
    Last Post: 01-25-2015, 03:48 PM
  2. Replies: 12
    Last Post: 07-01-2008, 08:21 AM
  3. Fusion Control Center skin
    By sxtnitehawk in forum Software & Software Development
    Last Post: 10-14-2007, 08:39 PM
  4. Feature Request: Advanced Volume Control
    By skeeter007 in forum Road Runner
    Last Post: 03-20-2006, 06:23 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
