ahh that button is called "toolstripbutton1"
port number to what i want? eg do i need to map a port on my router or???
the green tick box wont go green, so manually editing now.
and the ninji kitty brings up this message
"No Templates
there are no templates found, the wizard cannot output a file without at least 1 template"
the if you click ok it brings up an unhandled exception error
"cannot access a disposed object
NINJA_Form_Base"
attached debug info
debug_ninja.txt
i used the auto updater, which updated seemingly fast...
Edit
in theory if i have an empty/new FusionConfiguration.xml with just the code above in the general area, is that all i would need to access the web based config tool? which at that point i could build up a complete FB setup from scratch?
