Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 87
Thread: **NEW** Control Anything, Anywhere, Anytime w/ the FUSION BRAIN and Da Interwebz
  1. #41
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Woofnstuff View Post
    confirming that i only need to replace the Fusion Control Centre UberMDX.exe with the one dated 16-Aug-2008 05:52., from this directory?
    http://www.fusioncontrolcentre.com//...X/obj/Release/
    edit.... the one in the release folder there is only 1.1mb and the one that the updater brought in is 1.34mb, the one in in the link above has no remote at all it seems, and the one the update brought in is locked to port 4242
    despite this
    <remote status="enabled" user_name="" port="0"></remote>
    just noticed the font .png files were not in the configuration font dir so copied them from the source link, which has now stopped the font error messages
    more edits..
    got ninja kitty to work after manually copying files off the server, as suggested by dan.
    No. Read the last sentence in my post above...
    Debug, not release. And you need the binary, not the object.
    http://www.fusioncontrolcentre.com/M...MDX/bin/Debug/
    1.9in x 2.9in -- 47mm x 73mm
  2. #42
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    all works now as of the new updaterv4 release
    i think you have defiantly earned a week of sleep, thanks
  3. #43
    Mar 2006
    Glad it works for you.
    But no week of sleep. Classes start Monday. 20 credit hours + private chinese language course + 2 jobs + this. No rest until Winter Break in December.
  4. #44
    Dec 2008
    I'm having a problem with the remote control feature... it won't update any variable value or turn any output on or off, it just shows the start up variable values, port is set to 4242 and i mapped it...
  5. #45
    Mar 2006
    Quote Originally Posted by alejoal07 View Post
    and you made sure to change the user name to something in the configuration file and register that name online?
    Do you have MDX blocked with your firewall? And do you have port 4242 opened and forwarded to your computer?
  6. #46
    Dec 2008
    Quote Originally Posted by 2k1Toaster View Post
    I have registered the username and I can login and stuff, but it just shows the application start up values, and the outputs won't turn on or off even if i click update now.
    I guess it's something with the port?
    This is what I have,
    Code:
    <?xml version="1.0" encoding="utf-8" ?>
    <FusionControlCentreConfiguration version="3.0.0.0" author="Alejandro Alvarez" date_created="Tuesday, December 09, 2008 at 2:29:01 PM" last_modified="Monday, December 22, 2008 at 1:10:50 AM">
      <require>
      <!-- Begin Function Instances -->
      <!-- End Function Instances -->
      <!-- Begin Fusion Font Instances -->
          <font name="Verdana" originalSize="25" font_config="content\fonts\Verdana.xml"></font>
      <!-- End Fusion Font Instances -->
      </require>
      <speech enabled="false" global_politeness="true">
      <!-- Begin System Speech Instances -->
      <!-- End System Speech Instances -->
      <!-- Begin System Speech Definition Instances -->
          <system_definitions>
          </system_definitions>
      <!-- End System Speech Definition Instances -->
      <!-- Begin Custom Speech Definition Instances -->
          <custom_definitions>
          </custom_definitions>
      <!-- End Custom Speech Definition Instances -->
      <!-- Begin Custom Query Instances -->
          <custom_queries>
          </custom_queries>
      <!-- End Custom Query Instances -->
      </speech>
      <general>
      <!-- Begin Remote Control Configuration -->
        <remote status="enabled" user_name="alejoal07" port="4242"></remote>
      <!-- End Remote Control Configuration -->
      </general>
  7. #47
    Mar 2006
    when you login does it show your brain's name? Or just the default? Can you post a screenshot of when you login please
  8. #48
    Dec 2008
    yeah i see the brain's name, I think the problem is with the port, probably not being forwarded?
  9. #49
    Mar 2006
    yup sounds like a port forwarding issue. Are you running anti-virus? Behind a router? Behind a firewall? How are you forwarding it?
  10. #50
    Dec 2008
    Tried turning off my antivirus and it didn't do it, my computer is behind a dsl switch and that's it, i only mapped the port in windows firewall... anything else I should do to forward it?
  1. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
