Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 87
Thread: **NEW** Control Anything, Anywhere, Anytime w/ the FUSION BRAIN and Da Interwebz
  1. #51
    Mar 2006
    Colorado, but Canadian!
    DSL switch? Router or modem? Can more than 1 PC be connected to it? If so, then you need to forward it from the dsl unit too. If it is just a modem then probably only the PC.
    If you have a port blocking antivirus, then turn it off, restart the computer, and try.
    1.9in x 2.9in -- 47mm x 73mm
  2. #52
    Dec 2008
    My pc is plugged into a dsl switch (in which 3 PC's are plugged in), which is connected to a dsl router (in which you could only plug one in)
  3. #53
    Mar 2006
    the one that plugs into the wall is the modem. The one that plugs into that is a router/switch.
    The router/switch has to know where to send the packets. So you need to setup forwarding on it.
  4. #54
    Dec 2008
    So if i plugged my computer directly into the modem it would work since there wouldd only be one way for the packets to go?
  5. #55
    Mar 2006
    Quote Originally Posted by alejoal07 View Post
    Yes, as long as your software is setup correctly and not blocking the port.
    All routers have forwarding menus, you just need to login to your switch and change the options.
  6. #56
    Dec 2008
    ok, now i have to figure out what the password is for the switch... I'll do it tomorrow and see how it goes, I gotta get some sleep now...
    thank you
  7. #57
    Mar 2006
    any update for you?
    I think I found a problem on my end now.
    Long story short, we use our main host for everything, and then a second free host just for 1 function we use in Remote Control. Now this second free host has blocked the same php function our main host blocks. So now I am looking for another free host for my 1 file
  8. #58
    Mar 2006
    Ok, fixed. It was the free host playing badly. Try now...
  9. #59
    Dec 2008
    No luck... could it be because i'm running Vista?
  10. #60
    Jun 2007
    this is sweet looks like a possible remote start replacement and car disabler amount many many other things great stuff when i get my carputer goin i'm definitely goin to have a FB in there
  1. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 08:42 AM
