Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 87
Thread: **NEW** Control Anything, Anywhere, Anytime w/ the FUSION BRAIN and Da Interwebz
  1. #61
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by alejoal07 View Post
    No luck... could it be because i'm running Vista?
    For once, Vista may not be to blame .
    My dev machine runs Vista Ultimate and it works. Before you try anything else, Ill put an update out using my exe so if the newest version of the exe doesnt work, then we can try other things.
    When you login, does it have your fb name and the correct variables and everything?
    1.9in x 2.9in -- 47mm x 73mm
  2. #62
    Mar 2006
    Ok, update went out a few minutes ago. See if this fixes your issue.
  3. #63
    Sep 2003
    Thousand Oak, Ca
    Remote control issue.
    I'm getting a “No Fusion Brain Instances have been reported using this user name” error when I log into the website. After checking the forums for similar problems I tried plugging my laptop directly into my cable modem (disconnected my switch), I tried the internet at work, another laptop and different ports. I have my firewall and antivirus disabled. I just received the board last week and the software is up to date. Do you have any other suggestions?
    Thanks, mike
  4. #64
    Mar 2006
    What does your configuration file look like in the remote section? Have you created a user account? I see no record of your IP even trying to attempt to configure your setup on the remote database. By your IP I mean the same IP used to post the message above.
  5. #65
    Sep 2003
    Thousand Oak, Ca
    I have created a account. here's the first part of my Fusionconfiguration.xml.
    <?xml version="1.0" encoding="utf-8" ?>
    <FusionControlCentreConfiguration version="3.0.0.0" author="Me" date_created="Friday, September 17, 2010 at 11:30:10 AM" last_modified="Monday, September 27, 2010 at 10:22:38 AM">
    <require>
    <!-- Begin Function Instances -->
    <!-- End Function Instances -->
    <!-- Begin Fusion Font Instances -->
    <font name="fusionfontled" originalSize="50" font_config="content\fonts\fusionfontled.xml"></font>
    <!-- End Fusion Font Instances -->
    </require>
    <speech enabled="false" global_politeness="true">
    <!-- Begin System Speech Instances -->
    <!-- End System Speech Instances -->
    <!-- Begin System Speech Definition Instances -->
    <system_definitions>
    </system_definitions>
    <!-- End System Speech Definition Instances -->
    <!-- Begin Custom Speech Definition Instances -->
    <custom_definitions>
    </custom_definitions>
    <!-- End Custom Speech Definition Instances -->
    <!-- Begin Custom Query Instances -->
    <custom_queries>
    </custom_queries>
    <!-- End Custom Query Instances -->
    </speech>
    <general>
    <!-- Begin Remote Control Configuration -->
    <remote status="enabled" user_name="mskrzat" port="4242"></remote>
    <!-- End Remote Control Configuration -->
    <!-- Begin COM -->
    <com status="enabled">
    <commands>
    </commands>
    <executable_commands>
    </executable_commands>
    </com>
    <!-- End COM -->
    </general>
  6. #66
    Mar 2006
    Ok mysql searching through all user names registered, there is no "mskrzat" user. However, manually looking at some of the more recent registered users, there is a "1mskrzat" which I am guessing is you with a mispelled user name...
    Try to login with "1mskrzat" as the user name and see if that works. It would appear in typing haste, you made a boo-boo.
  7. #67
    Sep 2003
    Thousand Oak, Ca
    I first registered as mskrzat using your link http://www.fusioncontrolcentre.com/tcp/login.php. When I couldn't get that to work I tried using the register button built into MDX using the login 1mskrzat. The mskrzat account seems to work, it just doesn't see a my FB.
  8. #68
    Mar 2006
    Well would you be ok with me deleting your account for you so we can start fresh here. Somehow you are logging in with an account that doesnt "exist"...
  9. #69
    Sep 2003
    Thousand Oak, Ca
    Sure. let me know what you would like me to do on this end.
  10. #70
    Mar 2006
    I just deleted your accounts, make one new one and we will go from there.
  1. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 08:42 AM
