Page 9 of 9 FirstFirst 123456789
Results 81 to 87 of 87
Thread: **NEW** Control Anything, Anywhere, Anytime w/ the FUSION BRAIN and Da Interwebz
  1. #81
    Sep 2003
    Thousand Oak, Ca
    The LED doesn't come on when the jumper are in the USB mode, so i figured that's what made this board semi-defective (if that the only problem i'm very happy).
    I have tried 3 different ISPs and 4 computers it's possible they could all be blocking ports. Did I understand one of your previous post correctly, even if the ports are blocked my board's info should still get through, I just cant control it remotely? It looks like your site never sees my board at all.
  2. #82
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by mskrzat View Post
    If incoming ports are blocked, then you cannot control it.
    If the software is blocked to send outgoing messages, then you cannot send info to the server.
    The latter happens for many reasons. Sometimes an aggressive antivirus program, sometimes because you are not an admin user, sometimes because you have a router setup to block all requests outgoing on port ###, lots of reasons.
    I will try to get you a raw http request string that you can paste into a browser window to simulate MDX talking to the outside world. If that works, then you know it is something on the PC blocking it. Windows Defender is pretty aggressive unless you tell it not to be for certain applications.
    1.9in x 2.9in -- 47mm x 73mm
  3. #83
    Sep 2003
    Thousand Oak, Ca
    That would be great. I would love to get to the bottom of this.
  4. #84
    Aug 2006
    Central PA
    This is really cool. Being able to monitor my FB remotely, sign me up (figuratively ). Any plans in the future to be able to incorporatte a mysql database and be able to run reports from the data all from the web page too?
    I can't wait to play with this!
    Edit:
    So I've been playing with this. I get "No Fusion Brain Instances have been reported using this user name. Fusion Control Centre Uber MDX must initiate the communication."
    Steps I've taken:
    1. I set it up in the configurator. What's stopping someone else from using someone else username by the way?
    2. I ensured I had no firewall running on my local pc.
    3. I forwarded port 4242 to my computer.
    4. Double checked the config file to make sure that the correct line was there.
  5. #85
    Aug 2006
    Central PA
    So I gave this a few months and now I'm trying it again. I've forwarded the port "4242" I've setup a user and configured the software per the examples in this thread, and I still get
    This time around I've created a new user as well "scotty563." Is this working for anyone or is it just me that's having issues?
    This is the only MDX related entry I see in tcpview
    Fusion Control Centre UberMDX.exe 2296 TCP xxxx1243 ip-72-167-173-3.ip.secureserver.net:https https CLOSE_WAIT 1 702 5 2,008
    Port 1243 isn't the port I'm using in the software, and this port changes each time MDX is run so I don't think this is it. I tried forwarding it anyway with no luck.
  6. #86
    Mar 2006
    The server is down right now. It is being upgraded with another 8Tb of goodness and a few more Gbs of RAM. Full dump and clean in progress.
  7. #87
    Aug 2006
    Central PA
    Ahh very nice. Have fun with the upgrade .
  1. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
