Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: FCC freezing... blank config
  1. #11
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I know this thread is a little old, but I'm having problems with hibernation also... The brain itself is fine after hibernation, its the program that I'm having problems with.
    After it comes out of hibernation the program is transparent and you cant even click around to try to hit a button. But if i make it re-sizable then if i just grab the edge and resize it, then the graphics pop back and everything is good. The problem is that when its embedded into roadrunner i cant do this.
    When you come out of hibernation and the problem occurs the brain still works - I set it so one of the inputs would trigger an output and even when the program is messed up I can trigger that output so it seems to me its just a graphics issue.
    I had this issue before but ignored it hoping it was something stupid, then I got a SSD drive and did a fresh install of windows and fusion and i still have the problem. Also happens on my dell laptop.
    Debug mode does not give me any messages.
    I'm running Intel DG45FC Mini-ITX Board, Intel E4500 Core2Duo Processor, with Windows XP Pro SP2...
    Where do I begin to troubleshoot this?
  2. #12
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    heh, no idea I STILL Have this issue... exactly the way u described it...
    bump bump bump for nick
  3. #13
    Oct 2007
    Haledon, NJ
    there has to be something in common with our setups... it must not be happening to many others because no one else has brought up the topic really other than us... or they just aren't hibernating...
  4. #14
    Nov 2006
    Mentor, OHIO
    i got EVGA mobo, core2duo, xp sp2
  5. #15
    Oct 2007
    Haledon, NJ
    is your XP modified at all or shrunk? I took a few features out of mine, but that why i tried it on my laptop too bc that has a full version.
  6. #16
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by 2k1Toaster View Post
    [*]Advance Graphics Resume from Standby - The default DirectX had a bit of a problem on systems where it would resume blank. Well this is because the system never told the video card to redraw that part of the screen. Some did some didnt. With the addition of the ACPI events, I now force a redraw. So the screen might refresh itself 2 times on systems it worked for before, but at least it will redraw and you can see everything. It wasnt frozen, just not drawn. A way to force a redraw on some other systems was to change the size, but that is not needed anymore.
    This seems to the problem we are having still... Just thought I'd through that out there. I'm back to work after being off for 6 weeks so I haven't had much time to play with it, but hopefully in the next few days I'll be able to.
  7. #17
    Mar 2006
    Colorado, but Canadian!
    I think I may have finally sorted the issue. I am going to try and rush an update out tonight. I am compiling the full installer now, I will see if I can attach the exe for testing in a bit.
    1.9in x 2.9in -- 47mm x 73mm
  8. #18
    Mar 2006
  9. #19
    Newbie ATT41's Avatar
    Dec 2008
    Australia - Brisbane
    doesn't seem to fix the frozen image.
    When I switch user out of windows, and log back in, the image is still frozen/ broken.
    I did notice that when going into standby, outputs turn off and stay off. When just switching user, outputs stay on.
    [H]
    ____╔══════╗____
    OOO/ATT41\OOO
  10. #20
    Mar 2006
  1. Lilliput 619 Blank Sreen?? HELP
    By Shmeker in forum LCD/Display
    Last Post: 11-28-2007, 11:54 PM
  2. RR install and config PDF
    By accentsound in forum Road Runner
    Last Post: 08-21-2005, 08:27 PM
  3. Questions about RR config
    By Enforcer in forum Road Runner
    Last Post: 07-21-2005, 12:48 PM
  4. Store keypress config? and remote config troubles.
    By lilmansplace in forum Media Engine
    Last Post: 04-08-2005, 06:07 PM
