Results 1 to 10 of 20
Thread: FCC freezing... blank config
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    so i have fcc installed in my carpc and a desktop in my house...
    no mater what i do.. after hibernation or randomly sometimes... it freezes...
    i have no controls or anything in the config so im not sure what could be causing this....
    Mar 2006
    Colorado, but Canadian!
    Could be having to do with DirectX. Is this the latest version?
    Have you tried running it in basic video mode? Do you get a message when it dies or just the "program has stopped" blanket message?
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2006
    Mentor, OHIO
    its just program has stopped, i tried in basic too and it seemed to do it...
    its on 2 complete diff machines too :-/
    Nov 2006
    Mentor, OHIO
    still got probs on both computers, complete diff setups....
    always freezes after hibernate too
    Mar 2005
    more info on issue:
    dhantiflag1: its weird tho, its not like completely frozen, i can make it max then i can see ****, but u cant click buttons or what not
    Nov 2006
    Mentor, OHIO
    and it freezes with no brain connected*
    Nov 2006
    Mentor, OHIO
    Nov 2006
    Mentor, OHIO
    1 more weird issue* sorry to post so much...
    after i get the screenshot above... sometimes not always i can resize it and it comes back.
    Mar 2006
    Make a button on the page to change to a different page. Then try.
    If MDX is really frozen, it would not maximize or minimize or anything. And further if the change to a different page works, then it is hardware or driver related. I have put the program in hibernate, standby, even clicking things while entering standby/hibernate, and every time it comes right back to life.
    It is hard for me to fix something I cant even diagnose as a problem.
    Also run with the "-debug" command line switch. If there is an error, and it is freezing, an error message will popup and the program will tell the problem. I need that error if shows up. If it doesnt, then I know the program itself is ok. I am guessing it is either hardware or driver.
    Usually when I do testing I do it without the Brain hooked up. One of the reasons is it is a laptop and I program everywhere, usually not at a place where I plug in and test. Reason the virtual brain was born.
    Mar 2006
    Try the new update. I have removed all ACPI event handlers, and program closing handlers. So now it will just go blindly until closed.
  1. Lilliput 619 Blank Sreen?? HELP
    By Shmeker in forum LCD/Display
    Last Post: 11-28-2007, 11:54 PM
  2. RR install and config PDF
    By accentsound in forum Road Runner
    Last Post: 08-21-2005, 08:27 PM
  3. Questions about RR config
    By Enforcer in forum Road Runner
    Last Post: 07-21-2005, 12:48 PM
  4. Store keypress config? and remote config troubles.
    By lilmansplace in forum Media Engine
    Last Post: 04-08-2005, 06:07 PM
