Results 1 to 8 of 8
Thread: COM Sneak Preview
    Mar 2006
    Colorado, but Canadian!
    COM Sneak Preview
    With the help from Sonic, Fusion Control Centre is now COM enabled.
    You can start RoadRunner or FCC in any order. Once either is running you can close and restart either as well at any time, hasn't broken yet. I dont know the internals of RR, but it hasnt crashed or anything with FCC restarting. The DLL tries to always give back a value, so there shouldnt be anything wrong.
    More coming later, but here is a preview:
    1.9in x 2.9in -- 47mm x 73mm
    Newbie rightsidenov's Avatar
    Sep 2008
    Orlando, FL
    So what does this mean exactly? I'm relatively new here. I do know what RR is, as well as FB. But what is this COM thing? A way to communicate between the two? Was that not able before? Thanks!
    I can't wait till I build a carPC, get a FB and start playing around with it!
    Mar 2006
    Quote Originally Posted by rightsidenov View Post
    Yes COM is a way of communicating between the 2 applications. We supply our own software for free unlike others, and previously all you needed to do was just embed the application like you would a GPS app into any other program like RR or CF or SD.
    Now with COM, our program will run behind the scenes if you want it to, and your frontend program of choice can do the display natively.
    Mar 2006
    Blog Entries
    1
    Hurray! Been waiting for this a long time.
    Mar 2008
    Calling FB from app other than RoadRunner
    Any chance you can give me an idea of how to get started using the new COM interface from code (i.e. VB.net, not from RR)? I've tried a few different methods such as
    Code:
    Dim myBrain As New FusionCOM.FusionServer
    myBrain.SetDigitalOutValue(0, 1)
    myBrain.SetDigitalOutValue(1, 1)
    'etc...
    but I can't seem to make contact with the board. Is there something that needs to be done to initialize the connection and specify the board you want to communicate with?
    I appreciate that you're pretty busy so thank you for helping in advance...
    JoeBerni
    Mar 2006
    Quote Originally Posted by joeberni View Post
    Code:
    'etc...
    JoeBerni
    Some things to note:
    MDX must be running, it does the actual communication. MDX will initialize everything. MDX can run in the system tray from start, so that may be what you want.
    Then make a new instance of the Server Class. And call MyServerClass.xxxx where xxxx is:
    GetAnalogueValue
    GetDigitalOutValue
    GetDigitalInValue
    GetNumericVariableValue
    GetBooleanVariableValue
    Each of those functions takes an int32 as a parameter. The int is the index of the item as laid out in the configuration file. Object 0 is the first (topmost) and Object n is the last (bottommost)
    Also MDX must have the COM enabled by setting status="enabled" in the configuration file's general section.
    Mar 2006
    Also, if you want to set things, not just get (like change a digital output), then you will need to fire the COM_CommandReceived event either by calling it directly if your language supports it, OR by calling Server_SendBackCommandEvent which takes a string "command"as a parameter.
    The string command is interpreted by MDX as specified in the configuration file in the COM section.
    If your COM section looks like this:
    Code:
        <com status="enabled">
          <commands>
            <command id="myCustomCOMCommand" minimum_delta_vote_time="100">
              <do function="trigger output" functionTargetID="Digital Output 0" vote_opinion="on" vote_priority="medium"></do>
              <do function="trigger output" functionTargetID="Digital Output 1" vote_opinion="on" vote_priority="medium"></do>
            </command>
          </commands>
        </com>
    So if you call COM_CommandReceived("myCustomCOMCommand"); then MDX will interpret it and Turn on Digital Output 0 and Digital Output 1
    Mar 2008
    Thanks Nick! Appreciate the great (and fast) response.
  1. video preview problem
    By Morpheus2010 in forum Road Runner
    Last Post: 11-08-2007, 04:35 AM
  2. Preview for new features?
    By jAyRoCkS24r in forum StreetDeck
    Last Post: 12-25-2006, 07:31 PM
  3. flash skin preview
    By holistic in forum RR Skins
    Last Post: 07-09-2005, 05:17 AM
  4. sneak preview
    By FunkDaMonkMan in forum Bruno Speech Recognition
    Last Post: 05-12-2005, 12:59 AM
  5. AIMEE Sneak preview
    By Confused in forum Software & Software Development
    Last Post: 10-01-2004, 10:36 AM
