Results 1 to 4 of 4
Thread: Problem with Multi Image
    Sep 2008
    A problem with Multi Image feature (at least on my Vista).
    when i read a multi image directory the MDX short the images and assign the values taking the files #1= 1.png #2=10.png #3=100.png instead of 1.png, 2.png, 3.png and so on.
    look:
    Panos, SV1COX
    Oct 2006
    Las Vegas
    I believe you will have better luck using preceeding zeros in the filenames for the pngs.
    001, 002, 003, ... 010, 011, ... 100, 101, etc.
    That worked for me. (renaming the files)
    Mar 2006
    Colorado, but Canadian!
    Windows orders files by name alphabetically as if 1 was a character not a number if that makes sense.
    So 1, 10, 100, all come before 2, 20, 200, and before 3, 30, 300.
    So if the filenames are the same length will padded zeros, then 001, 002, 003, 004 will be in the right order.
    It doesnt actually read the file names, it just reads it in as Windows passes the file information.
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2008
    yes, it is fine now
    thanks
  1. image layering problem
    By Pistolen08 in forum Road Runner
    Last Post: 10-30-2006, 09:03 PM
  2. Replies: 17
    Last Post: 10-29-2006, 11:55 PM
  3. Strange power suplly problem.
    By seninha in forum Power Supplies
    Last Post: 10-22-2006, 06:32 AM
  4. Problem with DWW-700M - Fuzzy image
    By RobClubley in forum LCD/Display
    Last Post: 09-04-2005, 09:03 AM
  5. Replies: 0
    Last Post: 09-02-2005, 03:38 PM
