Results 11 to 20 of 21
Thread: Fusion Control Centre Uber MDX Release - Version 3.1.0.535
  1. #11
    Mar 2006
    Colorado, but Canadian!
    How to use COM: com
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Sep 2008
    Quote Originally Posted by 2k1Toaster View Post
    Download the new installer here: http://www.fusioncontrolcentre.com/F...g/software.php
    It is around 8Mb now. It will check if you have .NET 3.5 installed. If you dont, it will download and install it for you (~200Mb).
    confused, the link still show the old installer with size of 284mb here.
    Panos, SV1COX
  3. #13
    Mar 2006
    Quote Originally Posted by sv1cox View Post
    Panos, SV1COX
    The website text does not relflect the change but if you actually clicked the link you would see it is only 7.3Mb
  4. #14
    Sep 2008
    lol thanks toast.
    Panos
  5. #15
    Sep 2008
    3 problems dr toasty....
    1. every time i close the skin window and reopen it FB is not there. I have to close it again, unplug the usb and plug it again. Then if i open the skin again everything is ok (FB is present and working).
    2. on the previous version if i clicked the lower part of my button i had the on/off effect. If i clicked the upper part i had a toggle effect. NOW i always have the toggle effect. Sometimes it returns always to the ON position others to the OFF state.
    3. installation wipes out all the old "content" directory. Maybe a notice here will remind people save their files somewhere out of MDX directory using the configurator and before the update, to prevent lost them.
    Panos
  6. #16
    Mar 2006
    1) h3rk mentioned this too. Areyou by chance using an AMD processor or HP computer?
    2) That is because it was broken before. If you want a toggle button, you just have to set the upclick to be the opposite of what the downclick is. If you run the wizard, and select toggle button it will do all this for you and you can copy the code into your skin.
    3) I can do a notice. Sorry about that. It shouldnt erase the directory, just overwrite things with the same name. I think the easiest is just make a "MySkin" directory and place your content in there or just name the content folder to "MySkin Content" or similar. Then MDX will never touch it.
    I am trying to figure out what causes #1. Are you absolutely sure you got rid of the old drivers?
  7. #17
    Sep 2008
    hi agn
    i am not near that laptop now but no it's not a HP it is a cheap Fujitsu Siemens, i am almost sure its on Intel.
    as for drivers, yes i unistall and delete all the old drivers and then rebbot but, i have to mention that, before install the new ones i could see in Device Manager a direcory "Other Devices" with a Fusion Brain inside, u can remove it but not "delete drivers". So i unplug the FB and it go away.
    It is like when you close the skin you also close the USB link with the FB.
    As for the buttons the sad thing is that i dont need toggle buttons. The oposite is the problem. I can not make a stable ON/OFF button. I will play with the wizard tommorow in case i did something wrong.
    thanks, Panos.
  8. #18
    Mar 2006
    hi agn
    thanks, Panos.
    For on off all you do is make the down vote a toggle. That is it, no uplick vote.
    Start a new thread and post your code for 1 button.
  9. #19
    Oct 2006
    Las Vegas
    Panos
    hi agn
    thanks, Panos.
    I'm not crazy!!!
    I've tried it over and over and it still loses communication on my laptop. The drivers seem ok in Devmgr but the software wont talk to the brain after running, closing, and restarting MDX. I did eventually get it to work on my carpc, but I had to be unusually persistant with unistalling previous drivers.
    I have two or three more PCs to try this on, but I'm still in the process of moving, so I'll do more trials with this problem when I can (next week, probably).
    I am available for testing any possible fixes or troubleshooting on my laptop, if reproducing the issue isn't possible.
  10. #20
    Sep 2008
    dr toasty
    drivers come with the new installation have the date: 28/8/2008... is it ok?
    Panos
    P.S. its an Intel Dual Core laptop, buttons are ok now., thanks.
  1. Replies: 222
    Last Post: 09-21-2010, 01:39 PM
  2. XM / Sirius Worklog
    By Nola111 in forum Centrafuse
    Last Post: 08-20-2008, 11:05 AM
  3. Fusion Control Centre Uber Edition -- Need Testers
    By 2k1Toaster in forum FB Software
    Last Post: 06-12-2008, 04:29 PM
  4. Uber MDX Configurator Beta Testing...
    Last Post: 06-09-2008, 12:49 AM
