Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Fusion Control Centre Uber MDX Release - Version 3.1.0.535
  1. #21
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    Yep, Im having this driver issue as well.
  2. #22
    Dec 2010
    Wauconda, Illinois
    I was playing around with my spankin' new Fusion Brain V6 and fusegl. It was alright, but I need more control than just on/off buttons. So I looked at this Uber MDX... I removed any present drivers, restarted, installed the newest Uber MDX release as listed here, manually pointed windows to the "have disk" drivers under the \drivers\winusb, in the resulting list of fusion brain 3/4, I picked 4... and it says the device is ready to use. Restart. open Uber MDX, reports no fusion brains detected (only looks for versions 3 and 4?) I've reinstalled the program multiple times, manually uninstalled/cleared roaming/local... tried as many different driver "options", but I still got nothing. Am I barking up the wrong tree? Does this software not function with a fusion brain v6? If so, how do I go about control with logic/variables? I really liked what I was seeing made available in this Uber MDX package.
    I'm terribly sorry if I posted this in the wrong forum, this is my first post, I think. (wish it was under better circumstances!)
  3. #23
    Jun 2004
    Quote Originally Posted by Jigg007 View Post
    MDX will NOT work with v6 brains & it never will. It is at a dead end & will only work up to v4 brains.
    FuseGL has the power to do more than on/off buttons, but the configurator isn't set up to make it click & drag yet. you need to decypher the .xml configuration file to do what you want to do.
  4. #24
    Mar 2006
    Colorado, but Canadian!
    MDX will not work with the FBv6, it is dead software as Iamthehor said.
    FuseGL has all the capabilities of MDX and much much more as it is backed by everything C# can do. If you post what you are trying to do, I can help you figure out how to do that.
    1.9in x 2.9in -- 47mm x 73mm
  5. #25
    Mar 2006
    MDX IS NO LONGER SUPPORTED
    If you have a question about the new software, please make a new thread and it will be answered shortly.
  1. Replies: 222
    Last Post: 09-21-2010, 01:39 PM
  2. XM / Sirius Worklog
    By Nola111 in forum Centrafuse
    Last Post: 08-20-2008, 11:05 AM
  3. Fusion Control Centre Uber Edition -- Need Testers
    By 2k1Toaster in forum FB Software
    Last Post: 06-12-2008, 04:29 PM
  4. Uber MDX Configurator Beta Testing...
    Last Post: 06-09-2008, 12:49 AM
