View Poll Results: Which Drivers?
Voters
7. You may not vote on this poll
  • Previous Drivers -- Slower, Microsoft Only, Stable
    5 71.43%
  • Current Drivers -- Way Fast, Cross Platform, Willy Nilly
    2 28.57%
  • First Drivers -- Very Slow, Microsoft Only, Willy Nilly
    0 0%
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Fusion Brain -- New Drivers causing a headache?
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by RonS View Post
    Driver update. I am not sure if it is the driver or the plugin. But rrfusion no longer sees the FB. FCC sees it with no problems. So I am guessing it is the plugin. But the plugin did see it until I rebooted.
    I do not make or maintain RRFusion. MDX has its own RR COM object that works with the new driver.
    Also if it was working until you rebooted, then you did not completely uninstall the old drivers, which will cause problems later.
    The giant warning in the update thread was not just for decoration.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Dec 2007
    I was not sure if you wanted to know about it or not. Or if rrfusion used the same drivers. But this was a new install on a new computer. So no old drivers to uninstall. I am going to an uninstall and then reinstall just to see what happens.
  3. #13
    Sep 2007
    Raleigh, NC
    Sorry for the delay in posting back. I only encounter the freeze while using streetdeck. If I switch between different modules within SD, it will occasionally freeze (ie navigation, music, etc). Any attempt to close/reopen mdx is unsuccessful. I have to manually kill the application and unplug/plugin the brain before it works again. When I run it outside of SD, it will run indefinitely without problems. So on closer examination of the problem, I no longer think it is a driver issue.
    I am running Windows XP Professional SP3
    Via USB Controller r5
    If you have any insight, it would be helpful; though I dont believe the problem is simply the brain since it only occurs in SD.
  4. #14
    Mar 2006
    Well only thing I can think of off the top of my head is DirectX...
    I think SD uses DX. MDX can use DX. Maybe they are conflicting?
    If you run with basic gui mode, will it still freeze? Basic mode will draw everything in GDI+, and should not touch the DX core at all.
  5. #15
    Sep 2007
    Raleigh, NC
    Thanks. That did the trick. Works great now. Spent the past several days driving/making sales calls and havent had it freeze once.
  6. #16
    Mar 2005
    Quote Originally Posted by Disefyl View Post
    You have it set up in your car? What's it controlling/sensing?
  7. #17
    Mar 2006
    Well glad it works, but I don't know why it didn't. One of our programs isnt playing nice with the other... I will see if I can contact goc
  8. #18
    Sep 2008
    Hi
    here it freeze after speciffic tasks too (expect the "one run only" thing).
    are we sure that it has nothing to do with an other usb driver for another connected device?
    i use MDX to control the power of an ICOM 703 Radio. I control the radio via a CAT interface, on dm "Ports (COM & LPT)" i can see only the Silicon Labs CP210x USB to UART Bridge. (Vista OS).
    maybe is there a conflict beetween Fusion drivers and some bridges (to say at least) ?
    Panos.
  9. #19
    Sep 2007
    Raleigh, NC
    Currently I have my brain simply capturing steering wheel controls and controling the 12v reference on my amp. I am in the process of designing/coding an "anti-collision" system for checking blind spots. This project, however, is mostly in the proof of concept phase and hasnt made it far beyond paper.
  10. #20
    Dec 2008
    I would love to be able to use this with OSX or a unix command line.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Fusion Brain Reloaded
    By greenman100 in forum Fusion Brain
    Last Post: 12-17-2008, 11:00 PM
  3. How difficult is fusion brain to use?
    By 94gt in forum Fusion Brain
    Last Post: 04-22-2008, 12:41 AM
  4. Plans for Fusion Brain!
    Last Post: 04-17-2008, 12:30 AM
  5. Does Fusion Brain allow Hibernation
    By rgarjr in forum Fusion Brain
    Last Post: 04-10-2008, 01:30 AM
