View Poll Results: Which Drivers?
Voters
7. You may not vote on this poll
  • Previous Drivers -- Slower, Microsoft Only, Stable
    5 71.43%
  • Current Drivers -- Way Fast, Cross Platform, Willy Nilly
    2 28.57%
  • First Drivers -- Very Slow, Microsoft Only, Willy Nilly
    0 0%
Results 21 to 30 of 31
Thread: Fusion Brain -- New Drivers causing a headache?
  1. #21
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by RonS View Post
    Driver update. I am not sure if it is the driver or the plugin. But rrfusion no longer sees the FB. FCC sees it with no problems. So I am guessing it is the plugin. But the plugin did see it until I rebooted.
    RRFusion is only compatible with the older driver versions.
    Guys iv'e been testing the new drivers with MDX and i get freezes as well. No errors just stops receiving data from my temp sensor. Closing and reopening doesnt seem to work.. i have to reboot or unplug the usb.
    Live mp3Car Facebook Chat
  2. #22
    Nov 2008
    Quote Originally Posted by Sonicxtacy02 View Post
    The same thing happens to me, its like the connection is lost and the only way to restore it is to unplug the usb and restart MDX, just restarting MDX doesnt fix it
  3. #23
    Newbie ATT41's Avatar
    Dec 2008
    Australia - Brisbane
    I am having issues since upgrading the drivers. When using a single output relay with a virtual brain it seems to work fine, when using it on the actual brain, the MDX program looks normal (you can press the button) but the relay doesn't click, the orange LED doesn't light and there is no active 5V output pins.
    Mine was working fine with the old drivers but since I upgraded, I can't find where to download the old ones.
  4. #24
    Dec 2008
    never mind, had time to play around and fix it up, I had to install mdx + drivers and then I needed the updater to finish the install, is all good so far
  5. #25
    Mar 2006
    Colorado, but Canadian!
    Ok, I am switching back to Microsoft Drivers. I will not be porting MDX to Linux/Unix/FreeBSD for a while, and since Windows is what everyone uses might as well use a driver given to us by the same people.
    1.9in x 2.9in -- 47mm x 73mm
  6. #26
    Woodbridge, VA
    Blog Entries
    32
    wooo hoooo newRRFusion is dead.. for awhile!!! lol
  7. #27
    Mar 2006
    I cant say how long it will be before it is done. But I will be rewriting the FusionUSB.dll so that it is more stable.
  8. #28
    Jun 2007
    Hello there,
    I had to re do my system and decided to try the new software for my FB. I am having a problem getting the wizard to recognize my FB. When i look for my FB it comes up with an error and says LibUSB drivers are not installed properly... i have tried reinstalling everything multiple times and still no luck any ideas or is it jsut the same problem with the LibUSB.dll that others have been having?
  9. #29
    Mar 2006
    Quote Originally Posted by akitt08 View Post
    Hello there,
    Well if you have the FB connected, you have to install the libusb drivers for the current released software to work. Just like the error said.
    The installer does not update drivers, just software. You have to uninstall the old drivers, and install the libusb drivers from the Drivers folder in the default installation folder.
  10. #30
    Jun 2007
    how would you go about doing this? like i said it was a clean slate when i started so wouldnt all the new drivers and everything have been installed when i downloaded the package?
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Fusion Brain Reloaded
    By greenman100 in forum Fusion Brain
    Last Post: 12-17-2008, 11:00 PM
  3. How difficult is fusion brain to use?
    By 94gt in forum Fusion Brain
    Last Post: 04-22-2008, 12:41 AM
  4. Plans for Fusion Brain!
    Last Post: 04-17-2008, 12:30 AM
  5. Does Fusion Brain allow Hibernation
    By rgarjr in forum Fusion Brain
    Last Post: 04-10-2008, 01:30 AM
